caliper painting???
Old Aug 29, 2009 | 02:22 AM
dana dane's Avatar
dana dane
Default caliper painting???
i had a few questions. the search function provided a lot of answers so i canned this thread.
Old Aug 29, 2009 | 08:21 AM
jrose7004's Avatar
jrose7004
Search can be a wonderful thing if used!
Old Aug 29, 2009 | 08:24 AM
Bop Bop's Avatar
Bop Bop
Note: I painted mine with 2500º rattle can, engine paint (Chevrolet orange) and they came out great. Two years and no problems.
Old Aug 29, 2009 | 10:03 AM
VinnyT's Avatar
VinnyT
Pics?
I'd like to see the orange.
Old Aug 29, 2009 | 10:47 AM
minitech's Avatar
minitech
Dupont makes a kit for caliper painting. It is a brush on kit. Comes with a spray cleaner and brush, paint. I'd jack the car up completely and get all the tires off at the same time. Spray clean all calipers, start on one and move to the next putting layers of paint on. If you go around all 4 by the time you get to the first it will be ready for another coat. The first 2 coats look terrible. Need 3-4 coats and there is enough paint to do 3 cars at least.
When dry use a white paint pen to do the letters on the front. The pen has a flat brush/blade on it and if you carefully go over the letters it will cover well and look great.
Some people mask and spray but I think the Dupont kit which is purpose made for it and available at auto parts stores is fine. Made to be able to handle the high heat of calipers.
EDIT: Also get some black brake paint and paint the brackets black. Paint the rotors black also where they are rusty. If you go over the rusty area a little into the path of the shoe it will make a nice clean line for you when the brakes are used as it scrapes the bit of paint off.
Old Aug 29, 2009 | 10:58 AM
mcgilles's Avatar
mcgilles
I like more red in mine! I painted the caliper, brackets, and the back of the brake pads in red. for the front caliper letters I just scraped the mostly dry paint off with a blade. I painted the rotors silver, they came out great! they had a lot of rust on them to begin with so the paint didn't go on smooth, I really need new rotors.
Old Aug 29, 2009 | 12:19 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Originally Posted by VinnyT
Pics?
me too!!!! I did mine with the usual red but I am very interested! picspicspicspicspics
Old Aug 29, 2009 | 12:25 PM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
powder coat is the only way to go
Old Aug 29, 2009 | 12:39 PM
minitech's Avatar
minitech
Sure just after the $17.00 Dupont kit.
How much does it cost to have powder coating done??
Do you need to send off your calipers and have downtime with your car??
Is there any more expense with removing the calipers and flushing the brake fluid system??
Old Aug 29, 2009 | 12:54 PM
stingray4me's Avatar
stingray4me
I did mine with Duplicolor red brush on paint. 1 can will do like a dozen cars.l If you come over I'll paint yours for free. That is if you don't mind driving to Middle Georgia
Old Aug 30, 2009 | 09:37 AM
Bop Bop's Avatar
Bop Bop
Pics?
I'll snap a few pics and post them.
Old Aug 30, 2009 | 10:44 AM
jrc27's Avatar
jrc27
Cruise-In V Veteran
And they won't look nearly as good as the powdercoat. I started with painted calipers. The paint chips way too easily and the dirt and road grime sticks to the paint and makes them very hard to keep clean.
I paid less than $300 i think, that includes the brackets.
I did, but i did it during the winter when i have 7 months of downtime. I think the guy that does them on the forum does and exchange.
I bolted mine back on, bled the brakes and was done.
Old Aug 30, 2009 | 10:51 AM
o2z51's Avatar
o2z51
I jusy sprayed mine with duplicolor ceremic caliper paint, I masked off the pad and sprayed the calipers and the bracket, then with a nail file I went over the letters, the look perfect, and dont think they could look any better.
Old Aug 30, 2009 | 01:44 PM
jayindy's Avatar
jayindy
One of our CF members took a drill w/ wire wheel brush and made the alum calipers clean and bright. Pics looked great!
I think they were going to later paint the letters and clear coat. If you're that person, please post some pics of the final job!
Old Aug 30, 2009 | 04:24 PM
jrc27's Avatar
jrc27
Cruise-In V Veteran
Old Aug 30, 2009 | 07:43 PM
dobewillie's Avatar
dobewillie
A mod on my list
Old Aug 30, 2009 | 09:42 PM
o2z51's Avatar
o2z51
why is this funny??
To caliper painting???
Old Aug 30, 2009 | 09:48 PM
Oldvetter's Avatar
Oldvetter
Duplicolor makes a caliper painting kit with a brush, cleaner, paint and tape. It is ceramic paint. It takes about 3 coats. Works great.
Old Aug 30, 2009 | 09:53 PM
o2z51's Avatar
o2z51
They also make a spray, add some brake cleaner and your good to go.
Old Aug 31, 2009 | 12:05 AM
BAMvette's Avatar
BAMvette
St. Jude Donor '17
Here's yellow Duplicolor on LeMans Blue '04
