reading lights staying on
Old Aug 30, 2009 | 08:16 PM
LS3MODS's Avatar
LS3MODS
Default reading lights staying on
Rear view mirror reading lights won't go off. Replaced the battery today and restarted the car to make sure all was okay. Now the lights are staying on, so I guess my battery will be dead soon. Any ideas? Does the C5 have an accessory shut off feature after 10 minutes like the C6 does? Thanks for any help.
Old Aug 30, 2009 | 08:24 PM
2EZ 2SPD's Avatar
2EZ 2SPD
I don't know why it won't go off but mine does have a auto cut off I don't remember how long it takes though
Old Aug 30, 2009 | 08:26 PM
LS3MODS's Avatar
LS3MODS
Default lights
Finally went off after 15-20 minutes. Opening the door just started the process all over again. Usually they go off in a minute or so. Not sure if there is a way to adjust the time or not.
Old Aug 30, 2009 | 09:48 PM
GHL4505's Avatar
GHL4505
I don't mean to be a smart azz, but why don't you turn the light switch off that is on the mirror?
Old Aug 30, 2009 | 10:00 PM
2EZ 2SPD's Avatar
2EZ 2SPD
I was going to say this too but I was hoping we did not have to
Old Aug 31, 2009 | 02:19 AM
Jistari's Avatar
Jistari
You're sure its the reading lights right (not the action area light?). The action area light is in the center.
Check for an open hatch/trunk/hood, or stuck sensor (cause that will make the action area light stay on). And yup, the action area light stays on if everything is buttoned up correctly for a bit, not long (a minute or so), but it stays on sometimes (never figured out why).
If something else is open, the interior lights will stay on for 15 min then shut off automaticaly.
Of course, I also never figured out why a car that can tell me how much air is in the tires, has a computer in each door, can figure out how much to open the throttle but not too much to break somethig and can individualy apply one brake to pull me back from deaths door yet cant seem to manage shutting the headlights off by itself if I leave them on ?
To reading lights staying on
