Tail and dash lights out.
Old Aug 31, 2009 | 03:40 PM
RICK MCNICHOLAS's Avatar
RICK MCNICHOLAS
7th Gear
Default Tail and dash lights out.
Tail and dash lights out. Both went out at the asmes time.
What could this be???
RICK MCNICHOLAS
7th Gear
Tail and dash lights out. Both went out at the asmes time on 98 vette
Old Aug 31, 2009 | 03:47 PM
frodo84's Avatar
frodo84
Uneducated autodidact
They are both on the same fuse, that would be the first thing I checked. If the fuse is good, there are known issues with the tail/brake lights caused by a problem in the hazard switch or turn signal stalk.
Hope this helps.
Old Aug 31, 2009 | 03:52 PM
RICK MCNICHOLAS
7th Gear
Originally Posted by frodo84
they are both on the same fuse, that would be the first thing i checked. If the fuse is good, there are known issues with the tail/brake lights caused by a problem in the hazard switch or turn signal stalk.
Hope this helps.
thank you
RICK MCNICHOLAS
7th Gear
What is the fuse location cant find it , do you have any idea?
Old Aug 31, 2009 | 03:55 PM
RICK MCNICHOLAS
7th Gear
I know were the fuse boxes are just cant locate the fuse location
Old Aug 31, 2009 | 04:15 PM
frodo84's Avatar
frodo84
The owner's manual will have the exact fuse locations, there is more than one fuse box. Also, inside the fuse box cover there are abbreviations to denote which is which. I would look first at the box adjacent to the battery.
Old Aug 31, 2009 | 04:54 PM
RICK MCNICHOLAS
7th Gear
Is there a relay switch besides the fuse?
Old Aug 31, 2009 | 08:22 PM
widewheel's Avatar
widewheel
Try the #6 fuse in the passenger toe kick fuse box. Remove the toe kick pannel and the fuse box is on the right. The BCM (Body Controle Moule) is on the left. Don't mess with it. Fuse locations are mapped inside the lid. It's a 10A. You should have some spare fuses as well as a puller in the fuse box under the hood.
To Tail and dash lights out.
