[Z06] Dyno Run goes bad
Old Oct 4, 2009 | 05:41 PM
  #41
chet3310's Avatar
chet3310
AF doesn't look bad..... I vote spring
Old Oct 5, 2009 | 05:18 PM
  #42
camilio's Avatar
camilio
The car is fixed since 2 or 3 weeks... It was a 20$ broken spring. The compression on this cylinder is now at 195 until 205, not too bad!
What do you think about the dyno sheets?? Is the Hp better than stock?? I Don't know what the stock HP is supposed to be...
Old Oct 9, 2009 | 09:17 AM
  #43
Gideon's_Test's Avatar
Gideon's_Test
Glad you got it fixed easy & cheap!
Stock whp on a 2002+ Z06 is usually around 360...So you're up close to 20 hp with the headers, catback and X-pipe. Sounds about right...
Old Oct 9, 2009 | 11:35 AM
  #44
~Josh's Avatar
~Josh
Banned Scam/Spammer
Odd.
I tune on the street with hptuners both my N/A Zo6 and my old twin turbo Firehawk. There's no way I would have knowingly said 12.1 is lean.
Must have missed that part. Funny though how the majority of the thread focused on one erant comment. Sad, just like the politics and the media.
Old Oct 11, 2009 | 01:44 PM
  #45
AmMscl's Avatar
AmMscl
Originally Posted by ~JOSHUA
Odd.
Well it comes down to the doom and gloom statement as if it was broken to the point of a rebuild, when actually 12.1 is not a lean condition and the break had nothing to do with a lean condition.
The car was fixed with a 20.00 part and a rebuild was not needed, as you insinuated out the gate!
Old Oct 11, 2009 | 05:15 PM
  #46
~Josh's Avatar
~Josh
Banned Scam/Spammer
^ please stop. Too funny
Old Oct 11, 2009 | 10:16 PM
  #47
Z06 Bob's Avatar
Z06 Bob
Default Broken Spring
Careful here. Had a broken valve spring occur pulling into the paddock at Watkins Glen after a 25 minute session. The shop replaced all stock springs with Manley springs... I think.
1 week later broke a new spring just driving on the street 4th gear 50mph. Each time the symptoms were the same as yours. The first time code was misfire. Second time misfire and MAF code. The shop fixed the broken spring and told me to take it to the track. Did one day at Thunderbolt in NJ ... no problem. Next track day at Watkins Glen,blew the engine coming out of turn 10. Windowed the block. Everyone I talked to after said the engine should have been torn down to find the cause of 2 broken springs.
Good luck.
