Z51 sway bars
Old Sep 1, 2009 | 05:36 PM
vette.mix's Avatar
vette.mix
Default Z51 sway bars
Who out here has the C6 Z51 sway bars installed and was there a big difference over stock
Old Sep 1, 2009 | 06:17 PM
Bills03Coupe's Avatar
Bills03Coupe
Originally Posted by vette.mix
Who out here has the Z51 sway bars installed and was there a big difference over stock
I installed C5 Z51 bars on my 03'. The rear is identical to the Z06 bars, 23.6mm, and the front is only slightly smaller (28.6 mm vs 30mm). I definitely noticed a difference. The car corners flatter and feels tighter. A plus was I got them from a Forum member for free, all I had to buy were the bushings!
Old Sep 1, 2009 | 06:36 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
I bought mine but haven't had a chance to install them yet.
Old Sep 1, 2009 | 07:00 PM
Tikiman12's Avatar
Tikiman12
I installed c6 z51 sway bars on my c5 coupe. it's like night and day from stock I love how much better it handels
Old Sep 1, 2009 | 07:04 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
If you're referring to the C6 Z51 bars, yep, they're well worth it. I put a set in my '98 with base suspension and they made the car corner much flatter. And I still have the stock shocks. I also lowered the car all the way on the stock bolts, which probably helped the cornering a bit.
Old Sep 1, 2009 | 07:23 PM
Patches's Avatar
Patches
Installed the C6 Z06 sways in the wife's C5 and they work great.
http://forums.corvetteforum.com/c5-g...d-corners.html
Old Sep 1, 2009 | 07:29 PM
Mr.TT's Avatar
Mr.TT
St. Jude Donor '10, '15-'16
Best $110 I've spent on my base suspension C5. I have 9.5" front and 10.5" rear tires and the C6z51 sways significantly flatten out the car but maintain neutrality. c6z06 bars will not unless you have 12" rear tires, bigger is not always better!
Old Sep 1, 2009 | 09:02 PM
zx14's Avatar
zx14
Huge differance, I have 2004 Z06 springs and shocks, and after lots of research chose the C6 Z51 sways. I can pin a passinger against the door.
Old Sep 1, 2009 | 09:22 PM
redrckt97's Avatar
redrckt97
installed C6-Z51's on my base susp. 97 - huge difference... corners really flat on the street - no track time yet. Took three tries to get
the end links tight enough not to make noise but otherwise easy install.
Old Sep 1, 2009 | 10:00 PM
Vette Dog's Avatar
Vette Dog
where can I find a set?
Old Sep 1, 2009 | 11:02 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
It depends on how much handling you really want. If you go from smaller stabilizer bars, then they will feel make the car feel more stable; however, that is relative. If you head-to-head against another car with a stiffer suspension, you will have a different opinion. Personally, not adequate for me. I have had 4 different stabilizer bars and three different shocks. Currently, I use T1 bars...no comparison.
Relative Stiffness (Provided by Pfadt http://www.pfadtracing.com/)
C5 base: 0.4
C5Z06 : 1
C6Z: 1.2
C5 Pfadt Standard: 1.5
C5 Pfadt Pfatty: 2.5
GM T1: 3.0
Old Sep 1, 2009 | 11:31 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I have them on my base suspension car and love them. significantly better handling. I plan to put c6z06 shocks in when mine finally go and expect the car to handle even better.
Old Sep 1, 2009 | 11:56 PM
napacruzerc5's Avatar
napacruzerc5
Installed the front C6 Z51 sway bar on my '01 C5 F45 lowered on stock bolts. Really seemed to tighten up the steering at the first autocross I ran at after the install. Definitely flatter cornering. Still understeered at the slow corners, but less so than before. Adding the rear C6 Z51 sway bar may balance it out better; more neutral handling - or induce oversteer (don't want that since it had power oversteer with too much throttle). Maybe. Next autocross in two weeks; I think I can get it installed by then.
Old Sep 2, 2009 | 07:42 AM
Old'75'Owner's Avatar
Old'75'Owner
Recently changed to C6Z51 swaybars and C6ZO6 shocks on my 02' coupe with 25K on clock. The difference in handling is amazing compared to the cost of the swap! Dollar for dollar this mod gives you the most bang for the buck! For under $500 you can improve your handling and driving experience. Go for it!!
Old Sep 2, 2009 | 10:42 AM
ALVETTE00's Avatar
ALVETTE00
Yup I have them mated with the 04Z06 shocks and man what a difference over the base FE1 setup.
Old Sep 2, 2009 | 11:52 AM
BIG ATLANTA's Avatar
BIG ATLANTA
I have the C6Z51 sways with C6 Z06 shocks on my 2000 vert. I go to the mtns every month every other month and there is a definite difference
To Z51 sway bars
