major help needed please
I won;t rule out clutch though either...
My wife wanted a new car (mini), and my home computer crapped out so why not get that as well... argh...
The shop could not get the car to replicate the issue for them so I drove it again and the problem has gotten worse. it is now happening in every gear. When I accelerate quickly the lag is evidently the clutch slipping. After telling the shop, they said that is is 100% a slipping clutch. The chatter is most likely coming from the fly wheel, which is now slipping, and the smell was because when this first happened I never let off the gas, resulting in the clutch smell... This sounds correct to me...??..???
I replaced the clutch 2 years ago, but did not replace the fly wheel. I will be replacing all in the near future - or I might sell the car(undecided).
If I replace the clutch, what do you recommend? I had put a ram in before, but obviously am not going to do that again after my recent experience. I am thinking a z06 kit with flywheel? Thoughts?
