blackwing trouble
Old Sep 3, 2009 | 01:11 PM
USN32's Avatar
USN32
Default blackwing trouble
I'm installing a blackwing in my vette now and having a really hard time making the parts fit. I've read some stuff on the forum about getting the power duct to attach to the radiator shroud but everytime I try to do any of that stuff it comes undone where the filter attaches to the MAF. I have an 01 and am seriously struggling to get the right fit with the straight sleeve... Any help would be appreciated
Thanks, Matt
Old Sep 3, 2009 | 01:59 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
It is a huge pain in the ***. It took me forever and I almost gave up.. it does fit though.
Old Sep 3, 2009 | 02:18 PM
hotwheels57's Avatar
hotwheels57
I had the same issue with the (rigid) straight/thick after market silicone connector I initially used. You might consider just using the oem accordion bellows or the SLP silicone connector from SLP. It has a bump in the middle which allows for a little more flexibility.
My other suggestion is to install the system backwards, starting with attachment of the rubber grommets over the TORX pegs on the cross member first. Use lubricant to facilitate the grommets installation over the pegs. Once you have the filter assembly installed, then continue backwards towards the throttle body. With the air filter and air bridge installed correctly over the pegs, you should be able to see where the silicone connectors need trimming or adjustments at the MAF, air bridge and throttle body.
Due to whatever reasons (high altitude, air leaks, etc), I experienced annoying codes after going through the installation. I eventually removed it and re-installed my (modified) oem Z06 intake assembly. It doesn't look as sexy, but it sounds the same as the "Blackwing" and performs as well if not better...and no codes.
The increased sound of the air flow into an after market intake system are what most owners associate with more power anyway...
Old Sep 3, 2009 | 02:41 PM
Patches's Avatar
Patches
What a lot of folks fail to realize on the Blackwing is that you often need to cut the coupler just a bit shorter to allow the assembly to lay flat. Otherwise, you'll have the problem you're describing more often than not. The last one (Mrs. Patches installed this one on her C5) we cut a little off the coupler and it fits perfectly. Cut a little at a time until you get the right fit.
I added the CF air bridge recently. I cut a bit off the red silicone coupler when I did this to get a good fit again.
Old Sep 3, 2009 | 04:49 PM
cdnguyred88's Avatar
cdnguyred88
Old Sep 3, 2009 | 06:58 PM
Fire 22's Avatar
Fire 22
Here is what I did when I installed one on my 01
http://forums.corvetteforum.com/c5-t...g-install.html
Old Sep 4, 2009 | 12:24 AM
jrose7004's Avatar
jrose7004
Take your time and have patience.
Old Sep 4, 2009 | 10:09 AM
j84buick's Avatar
j84buick
I wish I had a better answer then it just takes awhile to get it right...
Old Sep 4, 2009 | 01:45 PM
arkus's Avatar
arkus
I like that CF air bridge. Who makes it ?
I like the cf air bridge , who makes it?
Old Sep 4, 2009 | 05:22 PM
stlvette's Avatar
stlvette
Default Keep trying!
I feel your pain, I struggled too.......If I remember right I had to install the power duct and coupler then try to get the Blackwing in......I took a while but i got......I love the sound!
I have a corsa exhaust and it really completed everything.....
Keep pushin on.....you'll get it eventually
Old Sep 4, 2009 | 11:18 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Carefully press the MAF firmly onto the Blackwing and tighten the clamp. It is important that the MAF is completely pressed onto the Blackwing so that the grommets at the top of the radiator cover line up and the airbridge duct will fit just like it did with the factory stock airbox. Once you have it all together, put the grommets in the Blackwing. (Using silicon spray on the rubber grommets and frame posts will make the assembly easier.) Next press the entire assembled unit onto the posts in the frame. Then press the airbridge down and into place and install the coupler. This works every time for me.
Installation instructions:
http://97vette.com/howto/blackwing/index.html
Old Sep 5, 2009 | 11:01 AM
Patches's Avatar
Patches
West Coat Corvettes sells it, amongst others.
Old Sep 5, 2009 | 12:07 PM
USN32's Avatar
USN32
Where can I get the silicone spray or lube for the grommets? They are all lined up but I cant get them to slide in! Also, do you think I should buy an after market power duct/ air bridge? Vararam? Carbon fiber? would it make a difference?
Thanks for everyone's help.
Matt
Old Sep 5, 2009 | 12:21 PM
hotwheels57
Any lubricant will work. Use something that will stay in place for the next R&R. I use white lithium grease. WD40 will work, a little motor oil, anything slippery. Everyone has some product they like to use on tires/vinyl, etc. If you don't have anything, a little spit or WINDEX will work, but it'll dry out. Make certain you're trying to align the TORX pegs correctly to the grommets. The beveled side of the grommet goes over the pegs first.
You're in TX, so any hardware store, farm supply store, home improvement store, automotive parts source will have something slippery.
The air bridge is 99% cosmetic. If you like the looks, pick whatever you like the best. Unless you're making serious horsepower over stock, don't expect it's going to make a significant difference you can feel. And the after market air bridges don't have the mounting ears for the grommets/TORX pegs which support the weight and keep things aligned.
The after market air bridge can come with some issues. Because they're over sized, you might expect it to crush your hood insulator or not allow your hood to close as well or oem. Both have been documented by owners. An after market air bridge might also require drilling for the installation of the oem IAT. The use of one will almost guarantee the need to use after market silicone couplings as well.
The oem air bridge will support a lot more power than a stock horsepower LSx motor produces. CALLAWAY continued to use the oem air bridge on their upgraded C5 cars. You can also dress up an oem air bridge by painting the Corvette logo or applying an after market decal.
To blackwing trouble
