[Z06] Done with lowering...Alignment recommended now ?
Old Feb 19, 2002 | 06:01 PM
Z06 THIS's Avatar
Z06 THIS
Default Done with lowering...Alignment recommended now ?
I just got done lowering my car and was just wondering if i should have the car's alignment check or corrected?. I didnt feel any pulling or anything and any sort but was just wondering.
Also ANY body with a lowered C5/Z06 have ANY problems with tire wear of any kind ?
Info greatly appriciated !
Thankz Alot!
-Keith :jester
Old Feb 19, 2002 | 07:01 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Re: Done with lowering...Alignment recommended now ? (Z06 THIS)
Any suspension adjustments should require alignment afterwards! I lowered and then aligned mine! It was lowered by only cranking the stock bolts at all four corners and it WAS out of alignment afterwards!
Old Feb 19, 2002 | 08:01 PM
TX405Z06's Avatar
TX405Z06
Default Re: Done with lowering...Alignment recommended now ? (Glennm27)
I lowered and then aligned mine! It was lowered by only cranking the stock bolts at all four corners and it WAS out of alignment afterwards! [/QUOTE]
I guess I got lucky cause I did mine with only the bolts, no cutting or removal and my front end feels fine, but I only went down 3/4 inch
Old Feb 19, 2002 | 08:22 PM
Glennm27's Avatar
Glennm27
Default Re: Done with lowering...Alignment recommended now ? (TX405Z06)
TX405Z06, My car felt fine too after lowering but I had heard so many people say that once the suspension has been altered the alignment can not be the same, so I decided to get it aligned! It was out! It was done on a Hunter Alignment rack and I walked in with all the alignment specs in hand! I had also put new wheels and tires on at that same time and just didn't want to take any chances of wearing those new (and expensive) tires out prematurely! Hope this helps! I am glad I spend the $65. :chevy
Old Feb 19, 2002 | 08:31 PM
hcvone's Avatar
hcvone
Glenn, who did the alignment?
Old Feb 19, 2002 | 10:18 PM
hcvone's Avatar
hcvone
You have really become a Zaino pig. ;) :yesnod: :yesnod: Bryner does good for Vette people, I will have to call them next week, we are suppose to get some bad weather next week.
Old Feb 20, 2002 | 12:15 AM
wottogo's Avatar
wottogo
Lowered with the stock bolts. It drove just fine for 300 miles. Took it in to dealer with new Hunter rack. 4 wheel alignment as all were out. $79. ( It drove just fine.....) yah right :bb
Old Feb 20, 2002 | 12:43 AM
SONIC99's Avatar
SONIC99
Just because a car feels alright, doesn't mean that the alignment is in spec. If you changed the ride height of your car, I would suggest that you have the alignment checked. If nothing else, It's cheap insurance against tire wear. :chevy
Old Feb 20, 2002 | 01:10 PM
Glennm27's Avatar
Glennm27
Default Re: Done with lowering...Alignment recommended now ? (hcvone)
Carl. Bryner did the alignment! They were pretty good there and took care of my car like it was their own! I am glad you suggested them! They are also very knowledgeable about Corvettes! Thanks
PS I think I have about 15 coats of Z5 on the car by now! Lookin Scweeet!
[Modified by Glennm27, 12:10 PM 2/20/2002]
Old Feb 21, 2002 | 01:37 AM
CP's Avatar
CP
in 18,000 miles after lowering and not aligning, my fronts were down to the steel belts on the inside.
At least get it checked.
Old Feb 21, 2002 | 06:25 AM
Z06 THIS's Avatar
Z06 THIS
Default Re: Done with lowering...Alignment recommended now ? (CP)
Cool , Thankz for the reply's guys!...im gonna wait a few more days for my car to settle then i will have it aligned!
I knew i was gonn ahave to have it aligned anyway , but i was just gonna ask anyway!...but Thankz Again!
-Keith :jester
Old Feb 21, 2002 | 08:59 AM
Glennm27's Avatar
Glennm27
Yea buddy! Don't forget to post some pics of that ML Z
To Done with lowering...Alignment recommended now ?
