Check engine light
Old Sep 4, 2009 | 11:07 AM
kwest2u's Avatar
kwest2u
Default Check engine light
how do you turn this off ? My gauges are all good ! No code for any problems, so whats up ? Can this be turned off ?
Old Sep 4, 2009 | 12:01 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If the light is on, there is a problem. You need to pull your codes and find out what is causing it. Push and hold the fuel button AND touch the Options button like 4 or 5 times in a couple of seconds. It will automatically go through the diagnostics but by using the fuel and trip buttons you can manually go through them. The E/M button exits.
Old Sep 4, 2009 | 12:21 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Did you just fill up with fuel? Check fuel cap for tightness?
To Check engine light
