Replacing Water Pump DIY? Pointers?
Old Sep 4, 2009 | 12:44 PM
2004 Z06's Avatar
2004 Z06
Default Replacing Water Pump DIY? Pointers?
I'm going to try and tackle replacing the water pump on my Z this weekend. Anyone have any suggestions or advice to avoid any possible pitfalls?
Thank you CF
Old Sep 4, 2009 | 12:54 PM
EBvette02's Avatar
EBvette02
I just watched my neighbor do this on my 02 coupe. Took him all of 30 minutes. its not very hard at all.
1. remove the air cleaner intake duct
2. remove accessory drive
3. disconnect the hoses from water pump
4. remove the water pump bolts, 6 of them
5. remove the water pump gaskets, mine were metal so no scrapping needed
6. reverse the steps, and fill back up your radiator with dex cool.
7. drink a beer. oh hell, drink a beer between every step.
good luck.
i have pictures i can email you if you need them.
just pm
Old Sep 4, 2009 | 12:59 PM
knyght4's Avatar
knyght4
See part 1 of instructions:
http://www.ls1howto.com/index.php?article=1
Old Sep 4, 2009 | 01:15 PM
Vega$Vette's Avatar
Vega$Vette
good luck.
just pm
Don't forget to burp the system. Leave the cap off and squeezing the hoses helps. This will get air out of the system.
Air block will not let coolant get to the T-stat and the stat will not open.
Old Sep 4, 2009 | 01:20 PM
redrckt97's Avatar
redrckt97
is there a mileage range where the pump should be replaced - assuming it is not leaking?
Old Sep 4, 2009 | 01:33 PM
Vega$Vette's Avatar
Vega$Vette
Not really.
Old Sep 4, 2009 | 02:00 PM
2004 Z06's Avatar
2004 Z06
Thanks alot guys, all the info really helps doesn't look overwhelming anymore.
I'm gonna see if i can start on it tomorrow morning....and hopefully not have too many beers in between steps
Old Sep 4, 2009 | 04:15 PM
WKMCD's Avatar
WKMCD
It's pretty simple nut and bolt stuff if you can turn a wrench. Mine went out at 45k.
Old Sep 4, 2009 | 06:07 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Someone say "turn a wrench"?
To Replacing Water Pump DIY? Pointers?
