Headlights wont turn on
Old Sep 4, 2009 | 11:02 PM
andrewjhaley's Avatar
andrewjhaley
Default Headlights wont turn on
I am having a problem with my head lights not turning on. I noticed tonight that one of my fog lights was not on, decided to wait till morning to troubleshoot but it started to progressively bug me. When I got home I turned off the headlight , turned them back on, lights pop up but dont turn on at all. Try it a few more times then the right side head light comes on, flick them off and on again, no lights, flick off and on again, then just the left side turns on. Neither of them will come on now, thank goodness I waited till I got home to shut them off. Whats the deal? Checked one of the lobeam fuses and it is fine. Hi beams work fine. I have HID's and checked the fuses for those, they seemed fine, also could hear the relay click for them. Any one had this sort of trouble?
Old Sep 4, 2009 | 11:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I can't speak for issues with the HID type lights, but usually the headlamp switch is the main failure for stock headlamps. They can be repaired if you wish to or you can just replace it.
Old Sep 5, 2009 | 01:03 AM
andrewjhaley
I believe the headlamp switch is functioning properly, I can hear the relay that powers the HID ballast click. In any case, is there a way to test the functionality of the headlamp switch?
Old Sep 5, 2009 | 01:14 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Had this occur with both my C5s at about 40K miles...was the multi-function switch (headlight, turn signal, cruise control stalk switch) on the steering column....The switch is about $300 from GM...takes less than an hour to install with the proper tools and if you know what youre doing....Hafta take it to the dealer????..Plan on spending $600 parts and labor
Old Sep 5, 2009 | 01:23 AM
dgrant3830's Avatar
dgrant3830
Not sure how you can test it with HID's other than verifying that the power relays you are referring too are actually working. Then you would need to track down the power source that feeds the relays. Again, no clue on the HID's. Oh yes, the switch is $138 if you know where to find it. Exact match at least for a '99.
Old Sep 5, 2009 | 01:26 AM
The NNIAL8R
Is that a genuine GM switch???...If so, let me in on that action...I just bought a switch for a friend's 2000 Coupe from my GM dealer $235 my cost, retail was $336 .
Old Sep 5, 2009 | 01:32 AM
andrewjhaley
Is there a way I can test to make sure it is the switch? I can hear the relay click when I turn the lights to the on position. They were working fine, turned them off and then on again, no lights, off and on again, one light worked, off and on again, the first light stopped working and 2nd one started working, off and on again, no more lights. I will just go through the wiring tomorrow except for the stalk unless I know how to test it.
Old Sep 5, 2009 | 01:58 AM
The NNIAL8R
I dont know any way to test it...but both my C5s were doing the same thing yours is..I could hear the relays clicking..but the lights wouldnt work...I think the switch wasnt allowing the ground circuit to work properly...
If youre mechanically inclined I can talk you thru changing the switch...It's pretty simple if you have a set of torq bits and a driver for them...
Old Sep 5, 2009 | 11:20 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Did the HID's work when you first installed them ?
Use a multimeter and see if you're getting 12V to the incoming ballast line (red).
Old Sep 5, 2009 | 12:01 PM
dgrant3830's Avatar
dgrant3830
Actually the original switch in there is an AC Delco one. This link is for where I bought one for my '99. It was an exact match for the original...I'll PM it to you
Old Sep 6, 2009 | 03:29 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
The issue with hids is that the wiring you are using is too small. Resistance issue. I believe their are some adapters out there to help with the issue.
You may also want to make sure your head lamps are clean.
Old Oct 29, 2009 | 05:35 PM
andrewjhaley
I chased it to a broken ground on one lamp and faulty relays for both ballasts. Replaced them and no issues.
To Headlights wont turn on
