Mixing tire brands
Old Sep 6, 2009 | 10:18 AM
Florida Mike's Avatar
Florida Mike
Default Mixing tire brands
The other thread about using Michelins over Goodyear RFs lead me to think...
I need rear tires but the fronts are good. Any forseeable issue with putting new Michelin RFs on the rear with the existing Goodyears on the front?
Aside from looks any issues?
Thoughts?
Old Sep 6, 2009 | 10:29 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I was in the same boat so to spead, I seem to go through 2 rear sets to 1 front set, I needed rear tires and the front have about 60% left and want to change tire brands, So what I did was buy the same rear tires as the front and figure when it comes time to replace the rear agian the front will need to be replaced also, There is no way I want to run 2 different type of tires on my car, Looks alone won't work for me, As far as drive abilty I believe there is a difference the way 2 different tires handle the road.
Old Sep 6, 2009 | 10:32 AM
itzza427's Avatar
itzza427
Not really,,as long as they match on each axle. I did the reverse for a while,,fronts were gone but rears were still good. Even ran it at the strip a few times and took it on some moderate length trips.The only oddity was on the highway on expansion strips the Michelin's were quiet and got a real thump from the Goodyear's!! No serious problems on handling,,just better once they all match!!---Dang bill,,you type a lot faster than I do!! Nothing there when I started,,bam you're in there before me LOL!!
Old Sep 6, 2009 | 11:03 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
It's a common thing to do. I'll stop short of saying everybody does it. Like mentioned though run the same tire in pairs. Front or rears. There is some advice out there that says don't mix run flats with non run flats. I also wear out rears at twice the pace of the fronts. What could cause this phenomenon? Just kidding. The cause is probably the same for everybody. A heavy right foot. I've never had a matched set of 4 but I think in a month or so I will do the fronts with a pair that match the rear.
Old Sep 6, 2009 | 05:37 PM
Florida Mike
Thanks guys!
I am likely going with some Michelins RFs all the way around eventually but will start with some new rears first.
Old Sep 6, 2009 | 05:38 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
A matched set-they look better oh so cool. LOOKS!!!!!!!!!!!!!!!!!!!!!!!
My 2 cents have the same kind and size tire per axle, don't
worry about looks. The tire companys are the only one's that
worry about looks and the BLING crowd.
Old Sep 6, 2009 | 06:12 PM
ProGo98's Avatar
ProGo98
I'm on a two year rotation. Fronts one year, back the next. Right now I have Dunlops on front and Goodyear on back. Don't really feel any difference.
Old Sep 6, 2009 | 06:49 PM
steveovette's Avatar
steveovette
Never,ever mix tire brands or even treads within the same brands. You may not notice a difference while driving to the local McDonalds but you will when you make that sudden lane change to avoid that idiot in the ricer cutting you off on the freeway.
Old Sep 6, 2009 | 06:57 PM
dobewillie's Avatar
dobewillie
Interesting post but I'm due for shoes next year and Ill just pop for the same all around
Old Sep 6, 2009 | 06:58 PM
rebelheart's Avatar
rebelheart
I run Michelins on the back and Yokohama's on the front and track the car,no problems what so ever!
Old Sep 6, 2009 | 06:59 PM
jaguar5822's Avatar
jaguar5822
I don't know if I would agree with this, people who go racing often use different rated tires between the front and rear in order to better fine tune the handling. Just something to think about.
Old Sep 6, 2009 | 08:10 PM
Chicago1's Avatar
Chicago1
no probs for me on the track or street and I see others saying the same. So that's incorrect
Old Sep 6, 2009 | 08:50 PM
longdaddy's Avatar
longdaddy
no they don't. there are other, correct ways, to tune the handling. mixing tires is not it.
for street driving, mixing similarly rated tires between axles is OK. for road course usage, this will upset oversteer/understeer balance and the way it changes with temperatures - the car will be a lot less predictable and will require constant driving style adjustment. while I have seen it done, it is always because the driver had no other options (i.e. corded fronts from one set and had to use something else to finish the day)
Old Sep 6, 2009 | 09:02 PM
widewheel's Avatar
widewheel
I've done it a couple of times without incident, but then again I'm not running at Le Mans either. I think the main reason they tell you it's not good is that they want to sell you a set of tires instead of a pair. I don't think I would mix from side to side though.
Old Sep 6, 2009 | 09:33 PM
jaguar5822's Avatar
jaguar5822
Nevermind I was right, this is taken from hancook's website, it was the first that popped up with the info so I didn't feel like finding any others, I also read on a couple sites that although using a different compound on each axle is normal, the tread pattern, if any, should be the same.: http://global.hankooktire.com/compme...dNum=2&Seq=492
"The 2009 Hankook Farnbacher Racing Ferrari F430 GTC will be equipped with Hankook racing tire Ventus F 200 slicks, Ventus Z 207 rain tire as well as tailor made intermediates all in the sizes 280/650 R 18 at the front axle and 280/710 R 18 in the rear, fitted on BBS rims sized 11 x 18 inch. According to each track condition the team can select from different tread compounds offered for each axle and condition. To find a good compromise between the car’s balance as well as the tire’s durability, for the basic tire setup it is intended to use a one step softer compound at the front axle compared to the rear. Reflecting the different tracks that will see the new Hankook shood Ferrari in 2009, the choosen tire will probably tend to be more soft at Nuerburgring (Ger) or Spa (Bel) and more hard at Algarve (Por) or Catalunya (Esp). Due to the circuit, for Silverstone (UK) even an asymmetric use (different compound on left and right side) is considered."
Old Sep 6, 2009 | 11:42 PM
longdaddy's Avatar
longdaddy
you can live in your fantasy world and give all the internet advice you want, but it will not change the reality. while there may be professional racing tires available in different grades for the same brand and type of tire, none of them are accessible to us.
Old Sep 7, 2009 | 01:25 AM
jaguar5822's Avatar
jaguar5822
I'm not sure where you shop, but I can assure you that tirerack and other websites sell more than one type of racing tire. And slicks don't have tread patterns so you can mix and match as you see fit, though I would probably stick with one tire design that's available in more than one compound.
Here's a website with a wide selection of Hoosiers, please tell me why we wouldn't be allowed to buy them? https://www.rsracing.com/hoosier/hosindx.htm
To Mixing tire brands
Old Sep 7, 2009 | 01:40 AM
thisMSGgood4me's Avatar
thisMSGgood4me
Forget racing tires guys, the OP never said anything about using or needing those. I have to assume he meant normal street usage, and for that, I don't see anything wrong with mixing, as long as the tires match on each axle. I'd rather have mixed tires front and back that are in good condition than 4 matching tires with any of them in questionable shape.
Old Sep 7, 2009 | 01:43 AM
Mr.Bill's Avatar
Mr.Bill
I just bought 2 tires from Tire Rack and if you buy different tires that don't match the other 2 they have you sign a waiver telling you it isn't recomended. Just did this 2 weeks ago. Mine match, But the waiver was on the sales ticket.
Old Sep 7, 2009 | 01:46 AM
jaguar5822's Avatar
jaguar5822
That's true sorry OP. I've seen some pretty scary tires on cars before, I always put some distance between myself and people going 75 on a donut on the front of their suv
The plot thickens...hahaha
