Do You Smell That?
Old Sep 7, 2009 | 09:35 AM
Jacks2002's Avatar
Jacks2002
Default Do You Smell That?
Relatively new Corvette owner here (3 weeks), but a lifelong fan. When I'm done driving my 02, sometimes I'll smell a hint of . . . . something. It's not the tires because I've noticed it after fairly relaxed cruising. Is it the clutch? I've been driving a stick for years in a variety of other cars, and I have never noticed anything like that.
FYI: The car is a 2002. Before I bought it, I had it looked at by a GM Technician who certified it across the board, said the clutch was in "terrific" shape. (The previous owner was not into driving fast at all, just wanted a car he would look cool in.)
Is a little whiff here and there normal?
Old Sep 7, 2009 | 10:00 AM
NC99's Avatar
NC99
Probably the cats. My 2002 and 1999 the same thing. It's not a sulfur smell, but rather an old barn smell or something. I took my 2002 to the dealer and had them checked, 1 cat failed and the other was on it's way out. It will not throw a code, an actual test has to be done on the cats. They said the cats were fine when they drove it with their scan tool attached. I insisted that they test the cats the hard way, when they did, they said the cats were bad and replaced still under warranty.
My 1999 is the same way. Just going to buy aftermarket cats.
Old Sep 7, 2009 | 10:12 AM
Jims2001's Avatar
Jims2001
When I pull my 01 in the garage after I am done driving I smell the rear axle oil burning on my exhaust, really bad smell. I am going to fix it some day but it's not that bad of a leak and I keep checking the level it's just a little annoying.
Old Sep 7, 2009 | 11:17 AM
C5GARY's Avatar
C5GARY
Default Yes
It's a burned rubber smell, right? (NOT burning oil)
If so, I am getting the same thing in my 99 with 105K.
I also have a small clicking noise sometimes with slight on-off-on
throttle. I am wondering if it could be the torque tube.
I first thought it was the serpentine belt but replace that and still have
the same smell.
Gary
Old Sep 7, 2009 | 11:56 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There are some wires that Bill Curlee found (Tech Section) that find their way onto an exhaust manifold. As for smells, there is the burn't rubber, burning electrical, the clutch is a nasty odor and the cats will smell like sulphur.
Old Sep 7, 2009 | 01:49 PM
Jacks2002's Avatar
Jacks2002
Haha, well it sound like I'm not the only one! :-)
Old Sep 7, 2009 | 02:09 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Just a few weeks ago I started getting a smell when I parked, its def a burning rubber smell and im pretty sure its the tires, which are relatively new still.
Just kinda weird this is the first time in 3 years im getting this.
Old Sep 7, 2009 | 08:57 PM
buckg2's Avatar
buckg2
I also smell the smell
Old Sep 7, 2009 | 09:10 PM
memphis_vette's Avatar
memphis_vette
can you smell that smell?
Old Sep 7, 2009 | 11:57 PM
Cybermind's Avatar
Cybermind
I get the burning rubber smell all the time. I am beginning to think that some tire dust or debris eventually makes its way onto the tops of the mufflers since they are located so close. Maybe it's the accumulation of rubber dust. Could that be causing the smell? I know that in my case, I checked everything and found nothing that would cause a burnt rubber smell.
I did suspect the rubber couplings in the torque tube but if they were beginning to go bad and rub inside the tube, wouldn't there be tons of vibration, driveline looseness and/or noise?
Old Sep 8, 2009 | 12:52 PM
steveovette's Avatar
steveovette
Ha Ha. You guys always crack me up
Old Sep 9, 2009 | 09:36 AM
C5GARY's Avatar
C5GARY
Default Not tire dust
At least in my case.. I haven't burnt rubber in years, just easy driving.
I am thinking its the rubber couplings just slightly rubbing somehow.
I do have small clicking sound in my driveline but only sometimes..
suspicious. I live up a hill so there's been some load by the time I
get in the garage but that's about it.
I've never seen what's inside the torque tube though.. anyone??
Gary
Old Sep 9, 2009 | 11:45 AM
C6ZR1RM's Avatar
C6ZR1RM
I think "the smell" is coming from the cats and is normal as long as there is no visible smoke. My Z had 12000km when I bought it and I could smell "the smell" but more noticeable after beating on it. Im not worried about it my brother had a 95 Camaro and had similar smells after beating on it.
Old Sep 9, 2009 | 12:24 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Actually - it's the smell of fear from the other "lesser" vehicles on the road.......
Old Sep 9, 2009 | 01:06 PM
WvCorvette's Avatar
WvCorvette
Old Sep 9, 2009 | 01:18 PM
hotwheels57's Avatar
hotwheels57
I don't know what that smell is you're smelling...here's your sign. (Bill Engvall)
Old Sep 9, 2009 | 02:11 PM
RedLS1GTO's Avatar
RedLS1GTO
To Do You Smell That?
Old Sep 9, 2009 | 10:13 PM
Aerovette's Avatar
Aerovette
Originally Posted by redls1gto
Can you smell what the VETTE'S got cookin' ??!!
Old Sep 9, 2009 | 11:22 PM
dobewillie's Avatar
dobewillie
good luck with your problem
Old Sep 9, 2009 | 11:32 PM
Jacks02's Avatar
Jacks02
Sorry, can't help -- my 02 still smells and looks like new at 23K miles.
