New "A" Pillars Installed - pics
Old Sep 7, 2009 | 02:31 PM
American Hydrocarbon
Guest
Posts: n/a
Default New "A" Pillars Installed - pics
Thought I would treat BLU2K to a set of the Hydro-Carbon "A" pillars that I now have available. The install took about an hour. Gettin' ready for the Pensacola show on 9/19.
$295 shipped/exchange.
Order here:https://www.paypal.com/cgi-bin/websc...ton_id=7140763
Old Sep 7, 2009 | 02:47 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Looks good
Old Sep 7, 2009 | 02:57 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
WOW!! this is EXACTLY what I was thinking about the other day!!! Having the cf run all the way up the windshield like that. Are you going to be offering these in other colors as well?
Old Sep 7, 2009 | 04:46 PM
Guest
Posts: n/a
Any color you like.
All parts are custom finished to order.
GM color match, ok.
Old Sep 7, 2009 | 04:53 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I'm not a big carbon fiber fan. But THIS actually looks really sharp to me.
Old Sep 7, 2009 | 05:22 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Looks pretty darn good to me.
Old Sep 7, 2009 | 05:28 PM
black98c5's Avatar
black98c5
Looks great!!!
Old Sep 7, 2009 | 05:36 PM
YO-EL's Avatar
YO-EL
How is the install..?
Old Sep 7, 2009 | 05:39 PM
Chicago1's Avatar
Chicago1
This is what we need not cheese graters/louvers on the back of our tail lights. Any pics of this in silver carbon?
Old Sep 13, 2009 | 02:25 PM
Guest
Posts: n/a
Easy install. One hour tops. The instructions are in the C6 thread.
Pat
Old Sep 13, 2009 | 02:27 PM
Guest
Posts: n/a
Ellis - here is the install.
There is a plastic pin holding the lower trim piece to the upper inside "A" pillar trim. Remove the pin then pop off the lower piece leaving the upper trim piece loose. Then there is another plastic pin visible at the bottom of the weather stripping, remove it. Carefully start to remove the rubber weather stripping as there are two more plastic pins hidden inside that bulky piece of rubber. The rubber will just pop off those pins. Remove those two pins and put aside with the other one. Carefully pull the rubber weather stripping out of the groove and continue until almost at the top of the windshield. Leave the rubber weatherstripping attached but dangling, I stuffed the end in between the visor and top of the winshield just to get it out of the way. DO NOT REMOVE THE WEATHERSTRIPPING COMPLETELY AS IT IS NOT NECESSARY!
Now locate the four-five screws holding the weather stip channel and remove them as well as the channel. There will be some sealant goo on it so be careful not to get it on the paint/leather, etc. Next locate the six screws holding the "A" pillar to the windshield frame and remove them. The whole "A" pillar will now come off easily.
Install the new one in reverse. After the channel is re-attached push the rubber back into the channel until you get down to the bottom where the bulky end is. You will see where the two hidden plastic pins go in the bulky part of the rubber weather stripping. Insert the two pins, locate the holes that they go into and push them all the way in.(early C5 only had two pins so I had to drill a hole in the "A" pillar for the second pin, no biggie) Then locate the hole for the third plastic pin and push it in. Reattach the lower trim piece and secure the upper/lower trim piece with the other plastic pin.
I should have taken pics as I did this as it is very simple to do. I did one side at a time so I could compare how the weatherstripping was seated in the channel. Open and close the door (window up) to see if the rubber is seated properly.
This should only take an hour at most. The service manual was helpful with diagrams showing the diferent screw locations.
Old Sep 13, 2009 | 02:36 PM
Guest
Posts: n/a
As soon as you order them I will have pics in silver.
Here is the silver CF.
Old Sep 14, 2009 | 10:56 AM
Looks really good.
Old Sep 14, 2009 | 11:04 AM
MG RED 99's Avatar
MG RED 99
Those look nice
Old Sep 14, 2009 | 01:25 PM
IRON MAIDEN's Avatar
IRON MAIDEN
It's a bit out of my funds at the moment...... but I would sure love to see the red CF ones on a Torch Red C5.
Old Sep 14, 2009 | 07:14 PM
Guest
Posts: n/a
ttt
Old Sep 22, 2009 | 06:56 PM
Guest
Posts: n/a
bbb
To New "A" Pillars Installed - pics
Old Sep 22, 2009 | 07:10 PM
dobewillie's Avatar
dobewillie
Lookin sharp
Old Sep 22, 2009 | 09:24 PM
TEXHAWK0's Avatar
TEXHAWK0
I don't get it...
Carbon fiber has a function to save weight, but I don't like the way it looks exposed just for decoration.
Old Sep 27, 2009 | 03:00 PM
Guest
Posts: n/a
Originally Posted by TEXHAWK0
I don't get it...
You are correct in that CF has a weight/strength function but it can also be decorative
