Tire life?
Old Sep 7, 2009 | 05:03 PM
Old Man in a C's Avatar
Old Man in a C
Default Tire life?
Daily driver for wife. '03 vert. Nitto 555's. Down to wear bars.
25,000 miles. Sound about right? More? Less?
Suggestions?
Old Sep 7, 2009 | 06:05 PM
mitchcole's Avatar
mitchcole
You did well. Did the fronts wear evenly or tear up the insides?
Old Sep 7, 2009 | 06:08 PM
R Devil's Avatar
R Devil
I think anything over 20,000 would be great.
Old Sep 7, 2009 | 06:29 PM
Old Rotor Head's Avatar
Old Rotor Head
I'm on my 4th set down in Nokomis. Same temp and roads. The best I've gotten was 30k but man they were slippery. Oh, 130k miles on my DD and running Nitto 555's since my runflats gave up the ghost.
Old Sep 7, 2009 | 07:32 PM
Old Man in a C
The fronts are wearing evenly. I didn't measure the tread depth but I'm sure there's another 5-7K on them.
Funny thing, when I bought the car with 5,000 miles (30,000 now) I could see the front end was lowered. I raised it back up and against the consensus of opinions, never had it re-aligned. Never had the tires balanced again either. I think I'll buy another set of Nittos.
Russ
Old Sep 7, 2009 | 07:40 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I have a lot of problems with the rear tires, not so much the fronts,wonder why?
Old Sep 7, 2009 | 07:44 PM
Luster's Avatar
Luster
2003 Vert... 20,000 miles. My rears are nearly bald, fronts look brand new. And I don't drive it hard. Wierd.
Old Sep 7, 2009 | 08:34 PM
widewheel's Avatar
widewheel
My first set of new tires wore out on the insides of the fronts and in the center of the rears. I had a 4 wheel alignment and run a little less pressure in the rears now. Everything wears pretty evenly now.
Old Sep 7, 2009 | 08:55 PM
That's not a bad tire life at all. When I had my '00, the OEM Goodyears only had about 15K miles on the rear tires before they had to be replaced.
Old Sep 7, 2009 | 09:20 PM
SaberD's Avatar
SaberD
I wonder why?! if you are talking about the oem runflats, ive put around 10k on mine and still have plenty of tread. i dont exactly drive like a grandma either.
Old Sep 8, 2009 | 06:17 AM
mojo1's Avatar
mojo1
70k on my car , I think I am on set 5 on the rears , I drive it pretty hard or , fun I should say ....
To Tire life?
