[Z06] Newb questions- Z06- Please help.
Recently bought a 2004 Yellow Z 06 with a LT's, cat back and cold air kit, car also appears to have a small aftermarket cam as it has a slight rough idle and pulls harder than the other stock cars I drove the same C 5 Z's. This is my first vette and love the way it drives but have some questions for you experts- please chim in.
Car seems to track or drive funny down the road- like it needs a 4 wheel alignment or something? Will have it checked out this week, but if I drive the car on uneven road surfaces it wants to pull to different directions without turning the wheel. Any ideas?
I want to change the fluids to synthetics for the tranny, and rear end and wanted to know what brand of fluid (weights,..) is best for the C 5 Z06 vette? And how much to can I expect to pay to have the tranny and rear end fluid changed at a local garage?
What temps do you run in your Z for temp and oil temp in the car, rather is what is the normal range for these?
Lastly, I will not be putting my front license plate on the car and wanted to know where I can get the front ( not sure what you call this part), filler plate for the front of the nose? What is the part called and where can I can get one of these in Millenium Yellow?
Thanks for your comments.
These cars do have somewhat of a shaky idle compared to others, they had a pretty aggressive cam from the factory. Car could use some new plugs or it does have a cam like you said
Normal. These cars tend to track a lot. It's due to the wide rubber they come with. Much more noticeable on grooved or uneven pavement.
Any type of syncromesh will work for the tranny. I use Royal Purple Syncromax. For the diff i use M1 75w90 with some of the posi additive. Get them done at the same time, should be no more then a couple of hours of labor at any shop.
200-220 coolant temps and normally 190-210 oil temps around town. I have seen 230 during spirited driving. Sees 290 on the road course
License plate filler would be my guess. Check the classifieds here, ebay, or it's the dealer.
I'm by no means an expert and there are some here but, How's the tire wear? Could need an alignment, To me the active handling makes these cars feel a little weird (but I wouldn't drive without it on) Are you talking about normal driving or when your getting on it?
Rear tires are in good shape the fronts are slightly more worn, it may be time for an alignment. I will keep you posted.
Thanks again for the help.
Paul or anyone else - where can I pick up an owners manual for my '04 Z06?? **I am ashamed to say it did not come with one and did not look for it until it was purchased. I really need one to learn more about the car options.
Mike
As for your current handling issues:
- How "old" are the tires? The datecode on the side of the tire can be used to figure out how old they are. Perhaps they are original, i.e. 5-6 years old? The ride quality suffers as tires get older.
- The stock Goodyear tires were not run-flat tires. Many people "back in the day" freaked out with no spare tire and they didn't think the tire inflator and tire goo was a good solution so they replaced the F1 tires with run-flats. That could be another reason why your car doesn't handle as well as it could.
What I found was that my axle nuts were lose. After loosening them a bit and re-tightening them, my car felt like new again. No more pushing and pulling me during lane changes like you are describing.
Hope this helps, it sure helped me.
Also I wouldn't assume you have a cam. A good set of LTs with proper tune are worth 30-50 RHWP which is definitley noticeable. Rough idle could be a number of things from spark plug to 02 sensor. 02 sensors can cause rough idle prior to failing and causing the check engine light to come on, and a bad plug wire can cause chaos as well. I would visit an experienced tuner and make sure the air-fuel mix is right for your headers and intake and he can probably tell you if you need new plugs and wires as well. If your tuner dynos your car and you have significantly more than 380-400 RWHP then you know something's been done besides just headers and an intake.
Have fun!
What tires are on it? Sizes?
Check out this remote control LP holder:
http://www.corvettesofdallas.com/pro...roducts_id=514
-Adam
Corvettes of Dallas
What kind of plugs do most use in their Z06 with LT's, cat back, cold air kit? I might look to change them soon.
I plan on having the car tuned at G Force in Pearland sometime later this month, as I think it is "fat" based on the mileage in town of 13-14 mpg, Hwy is about 26mpg, are those numbers about normal??
Thanks again for your comments
Mike
Clear Lake City
I'm a recent Z06 owner too. I know mine is bone stock. My first mileage test was 14.88 but I'm not sure I filled the tank complete before I ran it. Filled it to the first click off. My next run was highway and it came out to 25. I ran a combined after that and got 20.
That 90 mph ramp squirrel could have been active handling kicking in. I've noticed mine feeling funny and seeming like it tried to straighten itself out when I went around a turn kinda fast. Careful on that hot rodding around on the highways. Save your license and take it to the track.
See if you can order a manual and one of those intro tapes that came with the car new. Will answer some questions if you watch that tape.
