Window issue
Old Sep 8, 2009 | 08:45 PM
Red98VA's Avatar
Red98VA
Default Window issue
When I shut the door with the window half down it is a loud thud and the window appears to shake. Is there something that holds the window in the center of the door? Like a track or something?
Old Sep 8, 2009 | 09:05 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
There is a few possibilities, do a search in here or Tech section.
Search for- "window rattle" or "window rattle fix"
Old Sep 8, 2009 | 10:25 PM
TEXHAWK0's Avatar
TEXHAWK0
I would pull the rubber plugs in the bottom of the door, and look for loose window regulator bolts.
If nothing is obvious, you may need to pull the door panel and check the clamps that hold the glass, or look for anything else that does not look right when you operate the window.
To Window issue
