power shifting destruction
Old Sep 10, 2009 | 04:14 PM
SaberD's Avatar
SaberD
Default power shifting destruction
how horrible is it for the tansmission to power shift? what usually breaks? is it only really bad if your car is heavily modded? is there a way to get the same times without power shifting?
Old Sep 10, 2009 | 04:22 PM
happa's Avatar
happa
I power shift my Vette at the track. Havent broke anything yet (knock on wood) but I also dont go to the track that much either. I see nothing wrong as long as you dont do it all the time and everytime you get in your Vette.
Old Sep 10, 2009 | 04:30 PM
longdaddy's Avatar
longdaddy
if you slip your clutch while on power, you will get a lot closer to the "clutch pedal stuck to the floor" issue. make sure to maintain your clutch fluid.
Old Sep 10, 2009 | 06:21 PM
versatile's Avatar
versatile
Sorry! I'm lost.
What exactly is a power shift?:o
Old Sep 10, 2009 | 06:25 PM
SaberD's Avatar
SaberD
Originally Posted by versatile
Sorry! I'm lost.
not letting go of the gas when you shift. then when you drop the clutch in the next gear you are at higher rpms and higher hp consequently. you have to do it very fast and be sure not to hit the rev limiter.
Old Sep 10, 2009 | 07:34 PM
dougbfresh's Avatar
dougbfresh
http://en.wikipedia.org/wiki/Powershifting
Old Sep 10, 2009 | 08:37 PM
ALLEGRO's Avatar
ALLEGRO
Hardest on the syncro's. Eventually it will grind going into the gears your power-shift to. Usually second starts and then third immediately thereafter.
Most people don't get the clutch completely disengaged and that is what causes the problems.
Be careful, she will take a lot.......but not too much !
To power shifting destruction
