Center Console Glove Box
Old Sep 11, 2009 | 12:41 PM
secondchance's Avatar
secondchance
Default Center Console Glove Box
I just picked up a C5 for a buddy in Canada. Glove box door opens only about 45 degrees and not full 90. Is this normal?
Old Sep 11, 2009 | 12:44 PM
mischiefse7en's Avatar
mischiefse7en
mine sort of does that too. if i pull it up and to the drivers side a little it opens all the way
Old Sep 11, 2009 | 12:54 PM
Jet-Jock's Avatar
Jet-Jock
Grab from the front using the cut out, it opens in a two step fashion.
Sometimes opening it from a different location will cause binding.
Old Sep 11, 2009 | 12:57 PM
Drop Top's Avatar
Drop Top
Lubricate it and it will open all the way.
dndrsn's Avatar
dndrsn
Pull the lid towards the driver side while opening to initially get it to open all the way, then oil the hinges. There's four pivot points on either end of the hinge. It will open easily after it is oiled.
Old Sep 11, 2009 | 01:12 PM
HG's Avatar
HG
Apparently the same guy who designed the cup holder did the glove box door.
Old Sep 11, 2009 | 02:16 PM
The glove box has a dual hinge action to it - you need to use a bit more force when opening it up but it should go to a 90 degree position. Try putting a little lubrication on the hinges - it seems to help.
Old Sep 11, 2009 | 02:24 PM
secondchance
Thanks guys. Really appreciate the tip.
Old Sep 11, 2009 | 02:28 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
may not be the case, but if the car has a "cover" on the original lid (my CE has an after market leather padded cover over the standard lid) it might bind a bit trying to open against the brake handle (if the handle is raised). mine does for sure. it takes a bit of extra effort to compress the padded cover a little against the handle to get it to open 90 degrees.
Old Sep 11, 2009 | 11:45 PM
Jacks02's Avatar
Jacks02
Had same problem -- a couple of drops of WD-40 on the hinge pivots fixed mine.
Old Sep 12, 2009 | 12:25 AM
91Vette's Avatar
91Vette
Good to know. My center console is doing the same thing. I hadn't given it much thought up till now. Will open properly and lube.
Old Sep 12, 2009 | 01:17 AM
jrose7004's Avatar
jrose7004
Jacks right!
Old Sep 12, 2009 | 06:57 AM
JerG's Avatar
JerG
"Apparently the same guy who designed the cup holder did the glove box door."
It could have been a guy who actually did the design, but a woman, Lucy La Hood, Senior
Project Engineer, Interior had a lot to say about the design as well:
"In addition, we had to do a lot of engineering to provide room for the console. The backbone left little room for the console. So, I worked with the Structure Engineer to make sure that we allowed every possible millimeter so that we could fit a phone or tapes inside. We also had placed a restriction on the top to make sure that the console lid wouldn't get to be too high when it was uncomfortable to use as an armrest."
Imho, I agree the ashtray and console design are two of the worst designs I have ever seen in all the cars I've owned. I really miss the look and function of my C4 cupholders.
Jerry
Old Sep 12, 2009 | 07:26 AM
RSchleder's Avatar
RSchleder
A little lub goes a long way!
Old May 11, 2011 | 06:26 PM
BEP1124's Avatar
BEP1124
Navigator
wow im so happy i found this thread, i thought my console was broken untill i found out its a 2 part design haha thanks guys
To Center Console Glove Box
