c5 headlight problem
Old Sep 11, 2009 | 05:20 PM
stevareno's Avatar
stevareno
Navigator
Default c5 headlight problem
I had a problem with my drivers side headlight. It appears that the housing on the gear assembly had come loose. I repaired that but now i have a different issue. When I turn my lights on, the passengers side light comes up and the drivers side stays down.. When I turn the lights back off, the drivers side light pops up and passenger side goes down. I can manually take the drivers side back down but I have the same problem again when I turn my lights back on. Any ideas as to how to fix this problem?
Old Sep 15, 2009 | 01:16 PM
bulldogblack's Avatar
bulldogblack
1st Gear
Default Having the same problem....
My gear was broken so I replaced with the brass gear and everything worked fine for a couple of weeks. Then one night I turned the lights off and the passenger went down but the driver stayed up. I manually turned it down, then turned the lights back on. Both came up but when I turned them off this time, both went down but drivers side popped back up 3/4 of the way. Still haven't figured this one out. Hopefully someone has suggestions other than exorcism.
