How do you reset "LOW" Range" on DIC?
Old Sep 12, 2009 | 05:31 PM
Jacks02's Avatar
Jacks02
Default How do you reset "LOW" Range" on DIC?
When re-setting the FUEL section in the Driver Information Center (DIC), the last item is "RANGE" -- and it consistently reads "LOW" even after a fill-up. Pushing the reset button has no effect. How do you clear it to make "RANGE" operable? (There is no mention of this in the Owners Manual or CF's search option.) Thanks in advance for your input.
Old Sep 12, 2009 | 05:38 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It should set its self after fill up. Try resetting your average mpg.
Old Sep 12, 2009 | 07:07 PM
Jacks02's Avatar
Jacks02
Thanks, Bill. PM sent.
Old Sep 12, 2009 | 10:04 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
mine always reads low until the next time i restart the car or after approximately 10 minutes after a fill up. don't know if that normal or not, but whenever i've checked it that's the way it has been.
Old Sep 12, 2009 | 10:44 PM
Mr.TT's Avatar
Mr.TT
St. Jude Donor '10, '15-'16
Range is calculated by gallons x avg. mpg. If you're sitting at the pump and reset your avg mpg, it will read 0. 0 mpg x 20 gallons = 0 miles range, hence the "LOW" warning! As soon as you start moving and get your MPG up a bit it will give you a real number.
Old Sep 12, 2009 | 10:46 PM
Jet-Jock's Avatar
Jet-Jock
Old Sep 12, 2009 | 11:04 PM
Jacks02's Avatar
Jacks02
Thanks guys! This is the first time I've posted a question, and again, you've proven why I enjoy this forum!
Old Sep 12, 2009 | 11:14 PM
rws.1's Avatar
rws.1
you should not be waiting until low range until you refill your gas tank.
The fuel pump is in the gas tank and cooled by the gasoline.
Letting the gas continously go to low range means the pump continuously is not cooled shortening its life....
Old Sep 12, 2009 | 11:47 PM
Jacks02's Avatar
Jacks02
Yes, I've read about that. In my case, tank is currently half-full, and never gets below one-quarter.
Old Sep 12, 2009 | 11:57 PM
Mr.Bill's Avatar
Mr.Bill
If you have a 1/4 to a half of fuel you have other troubles, The low fuel shouldn't come on untill less than 1/16 of a tank. Just a guess.
Old Sep 13, 2009 | 12:02 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
"Low" fuel is the same as "Reserve" fuel correct?
Old Sep 13, 2009 | 12:19 PM
Mr.Bill's Avatar
Mr.Bill
I never let mine get that low, But I believe there are 2 readings, First you will see low fuel and them a bit later you will see reserve...
Old Sep 13, 2009 | 02:06 PM
coolbubba's Avatar
coolbubba
Default Other way around....
"RESERVE" comes first then "LOW"....see it all the time.
Old Sep 13, 2009 | 03:34 PM
Mr.TT's Avatar
Mr.TT
He is talking about the range display saying low, not the low or reserve fuel warning. Your car will say "range low" even if you have a full tank if your avg mpg is 0, which it would be if you're sitting at a stop light and reset your avg mpg.
Your car is fine, what I posted above is what's happening to your car.
Old Sep 13, 2009 | 03:38 PM
Mr.Bill's Avatar
Mr.Bill
OK, Never noticed that on mine, I will have to look.
Old Sep 13, 2009 | 03:42 PM
Jet-Jock's Avatar
Jet-Jock
I think your both saying the same thing only from slightly different perspectives.
Anytime you reset that Ave MPG, Range is set to low until some new values are obtained.
Old Sep 14, 2009 | 10:49 AM
That's correct. When you see reserve - best head to the gas station before long.
To How do you reset "LOW" Range" on DIC?
