clutch fluid
Old Sep 13, 2009 | 11:47 AM
Dave concrete's Avatar
Dave concrete
Default clutch fluid
I'm going to change my clutch fluid today just want to verify that its Dot 3, and does it matter what brand I use.
Old Sep 13, 2009 | 01:07 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Originally Posted by 8VETTE7
You can use either dot 3 or dot 4 fluid. They are compatible. The difference is the dot4 has a slightly higher boiling point. Brand is not important unless you want to go with racing type fluid. My local parts place has Prestone brand on sale fairly often so I pick up a couple bottles when it is on sale. Buy a smaller container. The master cylinder for the clutch only holds about 2 Oz. A 12 Oz container will let you use the Ranger methog of replacing the fluid about 6 times. Open bottles of brake fluid tend to extract moisture out of the air so buying a large bottle probably means you will be throwing it away soon.
I personally use the Amsoil DOT4 fluid, it has a boiling point of 593 degrees F. but any brand will work.
Old Sep 13, 2009 | 01:59 PM
Ranger's Avatar
Ranger
In 2007 GM change the spec to DOT4 for all Corvette clutches, including the C5.
Suggest avoiding Valvoline and any house-brand.
I've used GM-brand Super DOT4 and Prestone DOT4 with equal good results.
Ranger
Old Sep 13, 2009 | 03:30 PM
Jet-Jock's Avatar
Jet-Jock
And make sure you've seen Ranger's discussion, pictures and video on this subject.
Old Sep 13, 2009 | 05:06 PM
rws.1's Avatar
rws.1
I respect Ranger's opinion.
Previously I was not aware he suggested avoiding Valvoline.
I have been using Valvoline DOT 3 & DOT 4 fluid for 4 years on our 3 Vettes without issue.
Old Sep 13, 2009 | 05:09 PM
HANNY's Avatar
HANNY
4 would be a better options, as stated its boiling point is higher
Old Sep 13, 2009 | 05:15 PM
Black04Z06's Avatar
Black04Z06
I've been using Valvoline for a while too.
Good to know.
Old Sep 13, 2009 | 05:52 PM
Ranger's Avatar
Ranger
In 2002, I tested one can of Valvoline's so-called "DOT3/DOT4" in my 2001 Z06. In otherwise pristine clutch fluid, the Valvoline leached to black immediately and wouldn't come clear with repeated swaps. It seemed to react badly with the seals. As a conseqence I switched to ATE SuperBlue Amber and the fluid cleaned up to normal.
That's why I don't recommend Valvoline. But if it is working for you, no reason to change.
After testing an assortment of fluids I settled in on GM Super DOT4 and Prestone DOT4. They perform equivalently. The Prestone is widely available and 1/5 the price of the GM brand.
Ranger
Old Sep 13, 2009 | 05:57 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Ranger
OP- and everyone else for that matter - If Ranger is replying you can bet he knows what he's talking about. He knows a C5 clutch and how to drive one as well
Old Sep 13, 2009 | 06:02 PM
z21ranger's Avatar
z21ranger
I used prestone dot 4 cleaned up nice
To clutch fluid
