question about wheels
Old Sep 14, 2009 | 03:05 AM
richard emmanuel's Avatar
richard emmanuel
Default question about wheels
Will the factory wheels on a c6 coupe be a direct bolt on with no fender rubbing issues on a c5. Wheels are 18x8.5 front and rear are 19x10. Will i need spacers, what size tires should i use
Old Sep 14, 2009 | 05:46 AM
MYLS6's Avatar
MYLS6
they will fit fine, you can run 305-315 rear and 285-295s or so up front there are tons of tires choices you will have to choose based off your driving style and HP... GL
Old Sep 14, 2009 | 05:55 AM
JerzeyJoe's Avatar
JerzeyJoe
Would the Traction control become an issue? I have read on here stories about the traction control activating when different size wheels are used. Just wondering.
Old Sep 14, 2009 | 06:25 AM
IMXCITD's Avatar
IMXCITD
yes....you can run them...direct bolt on. I don't think the traction control will be an issue...on one car...I have 19/20's...no issues.
Old Sep 14, 2009 | 08:01 AM
richard emmanuel
Default wheels
Thanks, just wanted to make sure before i buy tire sensors
To question about wheels
