C5 wont crank with key
Old Sep 15, 2009 | 08:59 AM
Rocket Welder's Avatar
Rocket Welder
6th Gear
Default C5 wont crank with key
My 1998 C5 is experiencing starting problembs, I have been able to get it started by turning the ignition on and attaching a alligator clip to the purple wire on the starter w/ an inline toggle switch and a wire to the positive on the battery. I have done Bill Curlee's Ignition swith R&R and thought that would solve the problem but NO LUCK. Can any one give me some insight.
Old Sep 15, 2009 | 11:47 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You've got it posted in the tech section already and seeing responses there too. I'll add here that it sounds like the TDR relay isn't engaging. Is your security light on the dash flashing? What kind of trans therefore clutch switch?
