question...front lower spoler
Old Sep 18, 2009 | 09:20 AM
pewter-FRC's Avatar
pewter-FRC
Default question...front lower spoler
i lowered my car and would like to remove the black front lower spoiler. but i think this directs air up into the rad. if i remove will the car run hotter??
tia
Old Sep 18, 2009 | 09:29 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
tia
I have read that you do need the front spoiler to direct the air into the radiator, I have also read that some have trimmed a bit off, On mine it trimmed its self....lol
Old Sep 18, 2009 | 10:11 AM
HP_Addict's Avatar
HP_Addict
do not remove it the car will run hotter. If the scraping bothers you then just trim it a little. BTW the spoiler is spring loaded so teh scraping will not hurt anything.
Old Sep 18, 2009 | 10:16 AM
pewter-FRC's Avatar
pewter-FRC
thats what it thought. it only scrapes going in/out of the garage
Old Sep 18, 2009 | 02:06 PM
SJC5's Avatar
SJC5
I need to do this as well.
What did you guys use to trim the spoilers? Tin Snips???
Steve
Old Sep 18, 2009 | 02:12 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
It's designed to scrape...
It only cost about 35-40 bucks to replace the entire unit (3 pcs)
Peace
Chip
__________________
..................Click for
02MillenniumVette's Avatar
02MillenniumVette
Old Sep 18, 2009 | 03:02 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Peace
Chip
Where the hell can you find the whole kit for that????? Cheapest I found was $129 on Fleabay. I need the center section and its like $80+.......
Old Sep 18, 2009 | 03:07 PM
RedLS1GTO's Avatar
RedLS1GTO
Old Sep 18, 2009 | 05:56 PM
You are right that the front air dam does direct the flow of air up into the radiator area. I personally would leave it on the car.
Old Sep 18, 2009 | 07:01 PM
Jims2001's Avatar
Jims2001
I took mine off to mount the front spoiler and it doesn't run any hotter.
Old Sep 18, 2009 | 07:13 PM
JanMan99's Avatar
JanMan99
I don't think I would remove it either.
As far as scraping coming out of your garage...I have two 2 x 6's, about 36 inches in length that I lay at the end of my driveway, cut the wheels at an angle...maybe a small scrape. Coming back into the driveway, I enter at angle and NO scraping. Lowered on stock bolts as well. GL
Old Sep 19, 2009 | 04:01 AM
Jistari's Avatar
Jistari
Day-um, what you driving there boy...a 4x4? dont be bashful...lower that thing.
I mean it looks great but if there is a dollar bill in the road, no matter how much you have on you, you gotta get out and pick it up cause the car wont go over it
Old Sep 19, 2009 | 04:10 AM
infinity4life's Avatar
infinity4life
Looks good; but are you taking bets on how long until it's goes CRACK?
Old Sep 19, 2009 | 06:10 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Peace
Chip
it also warns you that you need to be a little more careful
after 40,000 miles mine should be worn down but it is not. It still does its thing (scrape)
Old Sep 19, 2009 | 06:20 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Peace
Chip
I think I have pieces missing on mine , link?
Old Sep 19, 2009 | 07:02 AM
Mr.Bill's Avatar
Mr.Bill
Peace
Chip
I would like to know where I can get one for 35-40 bucks... I need a new one.
To question...front lower spoler
Old Sep 19, 2009 | 07:19 AM
RSchleder's Avatar
RSchleder
I wouldn't remove it, take it off and trim a bit off the bottom.
Old Sep 19, 2009 | 09:00 AM
vette.mix's Avatar
vette.mix
Old Sep 19, 2009 | 09:47 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
It's about $120
||--Genuine GM 3 Piece Frt Spoiler/Air Dam--||
10401458 – Center – 78.46
10419312 – LH – 16.55
10419313 – RH – 20.94
