For those who have pulled out your PCM I expect you noticed how all the wires that are connected to the two large plugs seem open to the weather
Did anyone coat the wire openings with dialectric grease or something ?
I did the R & R thing three times. You can bet your butt I coated it with dialectric grease.
I've had mine out to send to ECS. Reinstalled myself with no dielectric grease. There should be two rubber gaskets to keep out the weather. The gaskets are on the plug ends.
Chuck
Yep, that is not the area I am talking about......I mean along the sides of the plugs where the wires enter the plug body.
Chuck
You are correct, however an ounce of prevention........
