[Z06] Lowest cost DR option?
I have read 17s will fit on the rear of the c5z06 if I dimple the upper ball joint?
Are there particular 17s to look for? I am looking through the auction site to find 2 stock ones off a regular c5.
Do I want 17 x 8.5s or 17 x 9.5s to mount a 17" drag radial? I know on the older cars I always ran a 275/60 on a 15x8 but the smaller sidewall tires seem to like wider wheels for a given width.
I installed the ls7 clutch kit and a roller bearing.
Also, am I playing with fire to put any DR on a 90k mile car? The trans shifts real smooth, but I do not know the maintenance history on it before 70k.
Your power-level is higher by more than 10% and the LS7 clutch has more clamping power than the LS6 version.
With a sticky drag radial added, the likelihood of breakage in the rear goes up. So factor that into your budget. Here are the typical pieces to consider see post #2.
The tire options I'd suggest are:
MT ET Street Radial 275.40.17 will fit on C5Z fronts 17" x 9.5"
BFG DR 315.30.18 will fit on C5Z rears 18" x 10.5"
The MT are stickier, but will put more shock to the rear.
Preventing breakage is mostly about avoiding the classic driver errors.
Ranger
