[Z06] Running lights no work
Old Sep 25, 2009 | 04:38 PM
ZONick's Avatar
ZONick
Default Running lights no work
Every corvette I see has running light in the amber front markers, but mine never turn on. The blinkers work fine, but even when I click the lights to the first... click, they don't turn on.
Discuss...
Old Sep 25, 2009 | 04:52 PM
dcd58's Avatar
dcd58
Discuss...
The blinkers are a seperate bulb. Have you checked/ replaced the light bulbs?
Old Sep 25, 2009 | 05:27 PM
ZONick's Avatar
ZONick
I was wondering if it was separate. They probalby just need to be replaced. THey haven't worked since I got the car so I wasn't sure. Anyone happen to know the bulb it needs? I'm gonna be doing some work on my car this weekend anyway.
Old Sep 25, 2009 | 05:44 PM
umrjmac's Avatar
umrjmac
I haven't tried this out myself to verify that it works, but the last owner may have done the following (found on another forum)...should be easy to check and might save you a lot of time changing out bulbs.
Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not will not flash. Your front turn signals will operate normally, however.
EDIT: Nevermind, you mentioned that turning the lights on (first stop on the stick) doesn't turn them on either, so this probably isn't your issue.
Old Sep 25, 2009 | 05:51 PM
dcd58's Avatar
dcd58
Front Sidemarker light bulb size: 194/yellow(or amber)
Old Sep 28, 2009 | 07:14 AM
taegee2's Avatar
taegee2
Check your fuses and relays first. If the lights don't turn on when you switch them on, then it may not be your bulbs. This would also be easier to check first before pulling out the bulbs.
Old Sep 28, 2009 | 08:33 PM
zulatr's Avatar
zulatr
interogate the DIC.
When I pulled fuse #2 as in one of the posts above, it set some codes.
might get you on the right track if a fuse was pulled or relay disabled, which is another way to do the same thing, without turning off the reverse lights when unlocking the car.
Old Sep 28, 2009 | 08:47 PM
ZONick's Avatar
ZONick
I'll check the DIC. I know there are some codes, but mainly for other things in my engine... lol.
What was the combo to get the codes again? hod 1 and press 4 four times or somethign?
Old Sep 28, 2009 | 11:59 PM
Texan1Z06's Avatar
Texan1Z06
http://corvetteforum.shelor.net/Docs...d_Diagnostics/
Turn ON the ignition switch, engine OFF.
Press the RESET button to acknowledge any warning messages present.
Press the OPTIONS button on the Driver Information Center (DIC) and hold.
While holding the OPTIONS button press the FUEL button 4 times within a 5 second period.
System will first enter automatic display mode followed by the manual display mode.
To Running lights no work
