Well all did my first run in the vette, horrible if i might say. I rans a 14.074 at 108 spinning 1,2, part of 3rd. I dont have line loc i orded one from fastbird and a hurst t handle. I was wondering wut everyone runs. Heres my mods
complete vararamn intake,p/p throttle body,85mm mas,shorty headers,cant memeber x pipe,corsa tails,complete upgraded fuel system, p/p heads, z06 cam, and tune from rapid motorsports. With a 335 bfg tires. Any guesses. Thanks all
Drag Radials make a really big difference. Regular street compounds simply will not hook up well on the track. When Oklahoma owned my car, he used the Nittos.
im lookin to tube her out to fit a set of 355 nittos or slicks after i build my rear. the grove will be racing again10/10 im gunna be there, anyone else gunna be there
Try not to just mash the throttle. If you're spinning all through 1st and 2nd, then you need ease up and let it hook. Seems like you were launching at way too high an RPM for the tires. Easy on the launch, let it hook then roll the throttle on. If you're spinning second, lift of the throttle, then shift a little lower, and roll back into the throttle.
335s are already a pretty wide tire. IMHO, i think more work on technique is needed before you throw more tire at it.
well the first run i launched at 1500 and spun and the second time i launched at 1100 and still spunn, they are bfg aa traction, im figuring i didnt get them hott enough
