Hyperflash Problem - NOT LED's - Help!
Old Sep 29, 2009 | 07:22 PM
kwikfire's Avatar
kwikfire
Cruising
Default Hyperflash Problem - NOT LED's - Help!
Hey Guys,
Interesting problem. My 1999 Coupe seems to have developed an issue where the right turn signal flashes very rapidly (hyperflash). No burned out bulbs, and everything seems fine upon inspection. I've heard of this problem with LED's but my lights are completely stock. The left turn signal remains fine, and interestingly, when the hazard switch is used, both sides flash at the correct rate. I thought it may be a malfunction with the hazard switch, but if the switch is bad, is it possible for the problem to be isolated to just one side? Also, this happened just hours after a HUGE rain storm (I don't believe in coincidences...).
Any thoughts?
