[Z06] O2 sensors
Old Sep 29, 2009 | 09:15 PM
onempty's Avatar
onempty
Default O2 sensors
Hey guys I want to know how to disable the 02 sensors. The car came with a tune and I want to make sure that I don't lose it. Is there a way to disable them?
Old Sep 30, 2009 | 01:16 AM
ptindall's Avatar
ptindall
I hope you are talking just about the O2s downstream of the cats. You do not want to disable the ones upstream of the cats. My downstream O2s were disabled as part of my tune. Those O2 sims would probably work as well, but I don't know.
Old Sep 30, 2009 | 09:08 AM
onempty's Avatar
onempty
I keep getting P0420 and sometimes P0430. Just want to make it stop.
Old Sep 30, 2009 | 10:33 AM
onempty's Avatar
onempty
Where can I get 02 sims, the things that hook in line of the 02's to stop the code?
Old Sep 30, 2009 | 10:24 PM
onempty's Avatar
onempty
They do make them right? I can't seem to find them.
Old Oct 2, 2009 | 01:38 AM
striper's Avatar
striper
O2 sims are not available anymore, unless you find someone selling used ones on an auction site. The federal gov't. has made them illegal and they are not being made.
Old Oct 2, 2009 | 01:41 AM
striper's Avatar
striper
When the car was tuned the tuner should have tuned out the rear sensors and left the front ones turned on. You can then plug the rear fittings. If you are getting codes the tuner should look into your problem. Properly tuned, you shouldn't get codes with only the two front sensors activated. The rears being tuned out will not affect your car's emission testing.
To O2 sensors
