Removing Vert antenna
Old Sep 30, 2009 | 04:46 PM
Timbrr's Avatar
Timbrr
Default Removing Vert antenna
I'm pulling my side marker lights on a 2003 Vert. I have the outside tail lights out and can see the (2) screws I need to remove the antenna. After I remove these screws is there anything else I need to do? Will there be any problems when I go to reinstall the antenna? Thanks in advance.
Old Sep 30, 2009 | 04:55 PM
1FUNC5's Avatar
1FUNC5
it slides out of rubber grommet on fender and then wiring pulls out of wheel well going into trunk and plug is just under carpet....but other than that you have it covered.
