[Z06] Does this ean my car was re-ringed
I assume this is the infamous ring job for the oil consumption issues 01's had, if so i am actually happy but why would it say only one cylinder both banks
Anyone have insight into this, the dealership was clueless
Also there is one from 8/7/2006 that says V1409 - 04006 - Install Wire Kit Only - U.S. Manuals - WTF is that??
The oil life monitir is at 53% on this car and it was down to 1/3 of the way up to between the add mark and the full mark on the dipstick so i am assuming it is still using a little oil. Is some (53% is likely to mean it has about 3k since the last oil change) consumption normal. I can live with a quart per 4-5k miles.
Let me know if that sounds about right.
Thanks,
Robert
To the OP, change your oil, let it sit overnight on a flat surface, and check the level before start-up in the morning. Check the level the same way each 1000 miles and see if the car is consuming a lot of oil.
This is from document #894549
TSB 01-06-01-023A
http://www.rjsmith.com/gm-894549.html
Also item #04006 is the electronic column lock system.
i also thought this was specific to 2001 ls6 only, the paper shows 01-02 on the corvette
This ring swap "should" lower oil consumption to a more acceptable level. What is an acceptable level of oil consumption? That number varies as each GM dealer makes a review and determination, but Assistant Chief Engineer John Juriga states that one quart consumption in 2000 miles. But adds that altering to a more conservative driving style would contribute to reducing oil consumption.
That driving style would refer to lower engine rpms at no load or low MAP, in other words shift into a higher gear , lowering rpm when cruising around town.
The start of model year (M/Y) 2002 production implemented the new revised ring pack to the LS6 and then a couple weeks later it went into the LS1.
Please realize that the revised ring(s) , whether replaced under warranty or installed in production for the GEN3 engines were just a band-aid fix. The actual problems were in the GEN 3 5300 utility block i.e. the siamesed cylinder bores have a slot at the top 20 mm between bores as an additional coolant passage . This has caused inconsistant bore temperatures or hot spots that cylinder bore distortion. This is not good for oil control.
Another area was the loose cylinder bore diameter and bore taper tolerances . These added to the possible cylinder bore heat distortions make it difficult for the piston rings seal when high engine rpm and low MAP conditions occured ( ring flutter). Obvious proof are the design changes that the GMPT did for the LS2 ( which has much tighter tolerances ) that uses a lower combined ring tension than the OEM 9 lbs LS6 and has thinner 1.2mm rings( OEM LS6 1.5mm) .
Don't forget the inadequate LS1 PCV system , then LS6 PCV changes to the LS2 Pcv changes . All improvements yes,but still oil consumption is not eliminated. Factory race engines used for the street require a little tolerance
