Cornerlight Switchback LEDs
Old Oct 2, 2009 | 03:44 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Cornerlight Switchback LEDs
Quick question for those of you running LED switchbacks on your front corner lights...
When the DRLs are on, what color do they display; white or amber?
I know when the turn signal is engaged, the amber color is on, however are there any legal issues regarding the white DRL color? I read the earlier thread about how clear corner units are illegal, however am I correct in my interpretation of the LED switchback look?
Also (second question) is whether LED Switchbacks can be used in stock corner light housing or do you need a special corner light assembly.
Thanks!
Old Oct 2, 2009 | 04:08 PM
Deslok's Avatar
Deslok
Amber.
With headlights on, they are white.
Old Oct 2, 2009 | 04:36 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The tower switchback LED's are amber when the lights are off and white when they are on.
There are no legal issues with the switchbacks being white since there is also a second bulb in the DRL that is amber.
Yes, you will need a hyperflash fix harness to correct the hyperflash when going to LED's in the front.
We currently have all these items in stock and ready to ship if you are interested.
Regards,
Randy
Old Oct 2, 2009 | 05:13 PM
MSG C5's Avatar
MSG C5
Regards,
Randy
Thanks. So the DRLs are white when either the fog lights or popup lights are on, however amber when either lights are off.
Will they work with stock or aftermarket corner housings?
Old Oct 2, 2009 | 05:17 PM
jpandes's Avatar
jpandes
They should they have the same exact mounting base as the OEM bulbs. They also are white when the parking lights are on.
Old Oct 2, 2009 | 05:34 PM
MSG C5's Avatar
MSG C5
Thanks for the confirmation. These are the corner lights I'm considering and would like to add LEDs and I just want to make sure it will work.
http://www.corvetteguys.com/front-bu...sing-9704.html
Old Oct 2, 2009 | 06:42 PM
blacksedan87
The DRL's are amber when operating during the day with headlights or parking lights off. Parking lights or headlights on - they are white, but flash amber with turn signals or hazard flashers.
The LED's will work with the stock or aftermarket housings, because the LED unit plugs into the lamp receptacle just like the incandescent bulb it replaces. It's the receptacle that twists into the back of the housing, not the bulb.
Old Oct 2, 2009 | 08:51 PM
tracks03's Avatar
tracks03
I went the exact same setup: black housings (from corvetteguys) with LED swbks and the bypass harness (from Corvette enhancements). you shouldn't have any problems. as far as legal issues, i think as long as the DRLs are either white or amber, it's good. I've heard of some people just using all white LEDs w/clear corners.
if your planning on swapping them out yourself, there's a good write-up in the tech section: http://forums.corvetteforum.com/1561976208-post3.html
Here's a pic of mine w/the fogs on:
Old Oct 2, 2009 | 10:54 PM
MSG C5's Avatar
MSG C5
Thanks! Another example as to why this forum rocks!
Old Oct 3, 2009 | 12:10 AM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
To Cornerlight Switchback LEDs
