Speed Bleeder Leaks??
Old Oct 2, 2009 | 07:01 PM
Nick1's Avatar
Nick1
Default Speed Bleeder Leaks??
Did a recent brake job that turned out well and used Hawks pads (there great). At the same time I installed the speed bleeders. Lately the low brake fluid message came up and I was surprised that indeed I needed to add a considerable amount of fluid. Checked the calipers today by reaching through the wheel and found "dampnes" at the left rear tire. Perhaps I did not tighten that one well enough.
In any case, are they known to leak to some degree on their own? I hate to overtighten anything; what is the prefered torque? Thanks
Old Oct 3, 2009 | 04:48 AM
Choreo's Avatar
Choreo
It is probably leaking around the threads. Speed Bleeders sells a special replacement sealant in a bottle with a brush which you heat up and it restores them to "like-new". The sealant sometimes looses its resiliency after cycling the valve and will leak. As far as torque I just hand tighten mine with an small box-end wrench - never had a leak yet.
Old Oct 3, 2009 | 08:22 AM
csexton's Avatar
csexton
I've never had a problem with them leaking. Snug it down and you should be fine
Chuck
Old Oct 3, 2009 | 09:27 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
I removed my speed bleeders.. the bottom beveled ends that seat were entirely different from the stock bleeders.. maybe I got the wrong ones from Speedbleeder.. The rears held fine but the fronts would not at torque spec. replaced stock ones and work perfect. I didn't bother investigating but might be worth checking them against the stock ones.
Old Oct 3, 2009 | 09:50 AM
Black04Z06's Avatar
Black04Z06
The stuff rarely needed but I've used it a few times in the last several years. Good to have on hand, IMO.
Old Oct 3, 2009 | 11:13 AM
rboineau's Avatar
rboineau
Default Leak with speed bleeders
The thread sealant is necessary to prevent seepage/leaks when actually doing the bleeding with the screw open; the screw won't leak from the threads once properly tightened. I also had one of the four reluctant to seal and I had to tighten it harder than I would have liked. As another poster mentioned, you might make sure that you have the right ones--you probably do but it couldn't hurt to check. Sometimes it helps to tighten and loosen a problem bleeder several times, going a little tighter each time. That seems to "form" a seat and then it will hold fluid without being overtightened. Be careful not to wring it off or round off the hex(try several wrenches/small sockets over the screw and use the one that fits the tightest without slop). I also found that hard red sealant that comes on the screws to be poor, but maybe I just don't understand the stuff. I dug it out of the threads and replaced it with teflon tape. The tape will probably need replacing after I do a couple more bleeds but it works good so far. Good luck.
Old Oct 4, 2009 | 01:15 PM
Nick1's Avatar
Nick1
Thanks All!
Old Oct 4, 2009 | 02:45 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hmm..news to me...
Old Oct 4, 2009 | 10:25 PM
CaliforniaJack's Avatar
CaliforniaJack
Default Leaky bleeders
I ordered two packs of speed bleeders for my 2000 a few years ago. I flushed the braks fluid using them, but when I finished flushing, they wouldn't seal completely, so I had to replace the stock fittings for driving. I still use them for flushing purposes, but I can;t leave them in for driving. I examined the tips and they don't match the shape of the stock tips. If anyone wants mine I'll give them to you for the cost of postage.
To Speed Bleeder Leaks??
