Power steering help!
Old Oct 4, 2009 | 05:03 AM
1sickz51vette's Avatar
1sickz51vette
Default Power steering help!
So tonight some @$$ clown tried throwing a beer bottle at my car leaving a bon fire out in the middle of nowhere because they were jealous of a 13 year old C5 (pathetic). I was pretty pissed at that point and did a few donuts in the car (I know not the smartest decision), then imediately after lost power steering. When I got it home I seen fluid all under the hood, and where the steering coloum connects to the steering rack assembly it looks like the boot has slipped off. Is there fluid in this area where the knuckle connects to the rack and the boot goes, or am I looking at another serious problem? Guess its just one of those nights, hopefully thats the problem and nothing more... Thanks for any help guys.
Old Oct 4, 2009 | 12:35 PM
1sickz51vette
This is where it leaked out from...
anyone?
Old Oct 4, 2009 | 09:48 PM
1sickz51vette
nobody has any idea? I filled it back up with fluid, and its groaning like crazy when i go to turn the wheel... Can't seem to find the exact place its leaking from either, no one else has ever had this problem with the steering after hard driving?
Old Oct 5, 2009 | 01:17 AM
mikex7's Avatar
mikex7
What.. does this mean?
Why.. did you do this?
Old Oct 5, 2009 | 09:01 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Looks like it's time for a rebuilt rack. Zip Products in Virginia has the best price.
Old Oct 5, 2009 | 10:47 AM
1sickz51vette
I know it wasnt the best idea to do that, but like I said I was pissed after some random guy tried throwing a bottle at my car! I've read the horror stories trying to get the rack out, and my car is a Z51 with the powers steering cooler.... Does this make a difference?
Old Oct 5, 2009 | 11:03 AM
Mark C5's Avatar
Mark C5
Z51 isn't any harder than standard. The rack isn't that hard to get out IF you follow the service manual procedure and lower the cradle. Most people who have problems try shortcuts. Having the correct tools, of course, makes all the difference in the world. The most important tool for making the job easier in my opinion is a crowsfoot for the power steering pump lines.
Old Oct 5, 2009 | 11:10 AM
1sickz51vette
I'm going to have to take a better look at this before doing all this, maybe its just a line broke or something and the pump went bad from running dry. Thanks for the great info, zip products certainly does have the best price!
Old Oct 5, 2009 | 11:15 AM
TurboBerserker's Avatar
TurboBerserker
On my 97, there is a hose coming out of the steering rack and going to the PS pump that travels right over that knuckle. That little black plastic boot keeps the bolts on that joint protected, and in my case, with that boot off, the hose would get snagged when I turned sharply.
In your last pic, it looks like the hose on your car runs under the rack (see the bottom left hand corner in the last pic) and so this may not be an issue, but before you invest in a new rack, I'd check that hose for damage.
Old Oct 5, 2009 | 11:26 AM
1sickz51vette
Turbo, thanks for your great input. Wherever its leaking from it is slinging up on the belts and all over the engine compartment as well, is it common for these racks to go bad?
Old Oct 5, 2009 | 01:05 PM
Mark C5's Avatar
Mark C5
I wouldn't say it's common but it is certainly not unusual. Mine went bad at 70K.
Old Oct 5, 2009 | 01:11 PM
1sickz51vette
How can i definately tell its the rack and not the power steering pump itself? The wheels turn fine, just no power steering and makes alot of noise from the pump when I turn the wheel...
Old Oct 5, 2009 | 01:39 PM
Mark C5's Avatar
Mark C5
The best way is to pressure wash everything and then put the car on a lift so you can see where the leak is from underneath.
Old Oct 5, 2009 | 06:32 PM
1sickz51vette
just went outside and started it, for a minute the steering was fine and actually worked... then it started spraying up onto the belts again and making that grinding/groaning noise coming from the pump. Grrr this really sucks because I'm without a car, and as it is the ac compressor just went again along with some other minor things!
Old Oct 7, 2009 | 11:48 AM
1sickz51vette
Looks like I may have got lucky... I had my friend turn the wheel while I looked where it was coming from, appears it is coming from the power steering pump itself and slinging all over the belts. This would deff be much cheaper than replacing the whole steering rack, so I'm keeping my fingers crossed. stock power steering pump with 115k miles is about time huh?
To Power steering help!
