[Z06] DRLs aren't working
Old Oct 4, 2009 | 04:45 PM
Never Late's Avatar
Never Late
Default DRLs aren't working
Hey guys, the parking lights on my 2002 z06 arent working while i drive. If I switch my lights to just the parking lamps on then they do work so i know its not the bulbs? also when my headlights are on the work..Shouldnt they work once i release my parking break? thats how my ls1 camaro works.
Old Oct 4, 2009 | 05:31 PM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
Not sure what year it began to be controlled through the DIC, option 4 function button, I think.
If not, check the #2 fuse (under the hood).
Old Oct 4, 2009 | 10:42 PM
Never Late's Avatar
Never Late
fuse #2 under the hood says its for the approach lights? and its a mini fuse? did you mean to say a diff one?
Old Oct 4, 2009 | 11:00 PM
Z06_BluByU's Avatar
Z06_BluByU
in the fuse box under the passenger side floor board there are two fuses (big ones) marked DRL L and DRL R.. one could be bad.. it could also be the options like the other guy suggested..
check there!
Old Oct 5, 2009 | 10:17 AM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
Do your turn flashers work?
The DRL uses the turn/ emergency flasher filament in the bulb, not the park filament in the same bulb.
Old Oct 5, 2009 | 02:19 PM
Never Late's Avatar
Never Late
check there!
i did check the fuses, where can i get two new fuses for the DRL L and R? or whatever they are, they are larger and are a gray cube. Also i checked my options in the DIC and didnt see an option for DRLs
Old Oct 5, 2009 | 02:20 PM
Never Late's Avatar
Never Late
im a tad bit confused as to what you mean, so the DRLs use the turn signal bulbs not the parking light bulbs?
Old Oct 5, 2009 | 04:29 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
Same bulb different filament, dim one is park lights and the bright one is DRL and flashers. Here is a photo of a two filament as an example.
Old Oct 5, 2009 | 07:26 PM
Z06_BluByU's Avatar
Z06_BluByU
chevy dealer?!?! maybe a parts store like NAPA
Old Oct 5, 2009 | 07:27 PM
Z06_BluByU's Avatar
Z06_BluByU
seems like a small chance that both side filaments went out..but it is possible...
Old Oct 5, 2009 | 07:45 PM
geebutbut's Avatar
geebutbut
This is exactly what happened with my car. Replaced the bulbs and we were back in business.
Old Oct 5, 2009 | 07:49 PM
Never Late's Avatar
Never Late
is the correct bulb the bulbs that you can get to by sliding the front brake vent out of the way? i swapped out one of those yesterday for a new one and it didnt change anything..or are they farther in?
Old Oct 5, 2009 | 09:33 PM
Z06_BluByU's Avatar
Z06_BluByU
no kidding.. wow... thats certianlly the cheapest fix- isnt it?
Old Oct 6, 2009 | 07:38 PM
ZONick's Avatar
ZONick
I have the exact same problem. I'll subscribe to see if you get it fixed.
Old Oct 6, 2009 | 07:41 PM
Never Late's Avatar
Never Late
i checked. there wasnt an approach fuse in the spot, previous owner must have taken it out. What size fuse can i use from the spare ones? 15?
To DRLs aren't working
