I picked up an 01 Z06 last week and have had several other C5's over the years. I do not recall active handling being this intrusive.
It seems to easily engage when cornering. It may be in my head but it seems more so when making right handers than left.
I tried competitive driving and I don't notice a difference.
It is intrusive enough that it is disrupting my canyon carving but I do not want to turn the system completely off as i recall doing a 180 in a previous Z i owned when doing that.
On a secondary note is there any way to turn AH off but leave TC on. My Z breaks the wheels lost with even new tires and warmed up shifting from 2-3 let alone 1-2 and i would like TC
AH just seems way too intrusive - I have no error messages or anything - why does it come on so easily
Yea you have to have a problem with active handling and it will turn it off but leave traction on.
My understanding is you cannot turn off AH and leave traction control on. You can thru competitive driving mode turn off TC but leave AH on
How do i diagnose this issue. The car has oodles of power (it will break traction in 3rd gear with fresh rubber and a warm day. I don't care about having AH but i sure need TC.
Car definitely has an issue as again on the way home even if i tried in a left hand turn it would not come on, in right handers it came on fairly easily. Then when i stopped in my garage it said service active handling and service vehicle soon
I took it out to dinner and no messages??
What can I do now besides get bent over at the dealer. It is something with right hand turns, outside of that it is fine?????
Are you running stock wheels? I seem to recall reading that service active handling message appears with certain wheel size combinations?
I've run in competitive mode for 4 years without any problems. Has activated maybe twice that I am aware. I wouldn't have a problem with turning it off completely though since I found that switching to 18/19 wheels reduced the need for traction control.
