cd player
Old Oct 7, 2009 | 07:50 AM
riarms's Avatar
riarms
Default cd player
OK, so everytime I put a cd in my radio I get ERR. I was looking at radios on Ebay and found one from an 98 Blazer its Bose and looks just like the radio in my car. Does anyone know if it will work?
Donn
Old Oct 7, 2009 | 10:05 AM
Indy's Avatar
Indy
I suggest you get a nice aftermarket system. Dirt cheap these days
Old Oct 7, 2009 | 10:13 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Easy fix.... The laser is dirty.
I tried a few laser cleaners on the market that did not work.
I wrote a procedure on it when I fixed mine. (click link below) My CD player was not reading ANY CD's anymore. If I did get it to read it would skip like crazy. Now it reads them all and does not skip.
http://mysite.verizon.net/res0aae8/stereo.html
If your not sure how to remove the CD player then follow the first bit from my IPOD install procedure.
http://mysite.verizon.net/res0aae8/ipod.html
Hope this helps.
Toque
Old Oct 7, 2009 | 10:14 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Hope this helps.
Toque
Very cool, thanks for posting
Old Oct 7, 2009 | 01:04 PM
riarms's Avatar
riarms
wow, i may try this. im sure i can get it apart its putting it back togeter that scares me
Old Oct 7, 2009 | 01:30 PM
DeBaGo's Avatar
DeBaGo
Actually the write ups above are top notch, however...I am not very mechanically inclined. I followed all the steps but now I have no power to the CD. It will not even feed a CD in. Sigh.
Old Oct 7, 2009 | 02:12 PM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
Donn
to specifically answer your question:
NO, it probably won't work.
In my situation, I wanted to replace the tape deck in my '98 with a CD from a '99 or '00 blazer as well...can't remember the year exactly.
Did not work at all.
Old Oct 7, 2009 | 02:37 PM
Toque's Avatar
Toque
I just started taking it apart till I got to the laser. Just be very organized when your taking it apart. Set aside a nice spot on a table. Its not hard at all. Just be careful and take it easy. Don't force any wires apart. They should disconnect fairly easily. I wrote this procedure as I took mine apart for the first time . I had no guide to go by, and had no idea what I was doing.
I figured I had nothing to loose since it did not work anymore. It was either send it off to be fixed , or try it myself. Luckily for me it worked and I saved some $$ doing it myself. I hope my procedure can save you some $$ too.
Toque
Old Oct 10, 2009 | 05:45 PM
BodaciousBlue's Avatar
BodaciousBlue
riarms...are you still interested in purchasing the stereo the you PM me about. Please let me know so I can sell it to another forum member.
Reuben
Old Oct 10, 2009 | 06:10 PM
SaberD's Avatar
SaberD
i had a similar problem. it would play reguluar cds that you buy from the store and some selected burnt cds, but for some reason it just didnt like a lot of the burnt cds. never had a problem with ones bought at the store. i went with an aftermarket head unit. problem solved. looks way better too.
Old Oct 11, 2009 | 06:38 PM
riarms's Avatar
riarms
Thanks, it sure looks the same
Old Oct 11, 2009 | 06:40 PM
riarms's Avatar
riarms
Thanks but i dont want to lose my ashtry
Old Oct 11, 2009 | 06:41 PM
riarms's Avatar
riarms
Reuben
yes I am sent you a PM waiting to get your paypal address
Old Oct 12, 2009 | 10:51 AM
Nice writeup there, Toque. Thanks.
Old Oct 12, 2009 | 12:48 PM
Toque's Avatar
Toque
Thanks !
To cd player
