C-5 Battery replacement
Old Oct 7, 2009 | 02:39 PM
Ken Hattrick's Avatar
Ken Hattrick
Cruising
Default C-5 Battery replacement
I replaced the battery yesterday. Initially the HUD was inacurate. I used the "page" control, and was able to reset everything. My "gage" control is another thing. I get no PSI reading for my front tires. All te other items seem fine. Any thoughts? Disconnect the negative again? Maybe a fuse?
Old Oct 7, 2009 | 10:07 PM
mtdriver's Avatar
mtdriver
That sound really odd. I replaced my battery about a month ago and had no issues at all.
Old Oct 7, 2009 | 10:14 PM
rebelheart's Avatar
rebelheart
You may need to reprogram your TPS sensors.
Old Oct 7, 2009 | 10:29 PM
Just try reprogramming your tire pressure sensors. That should do the trick.
Old Oct 7, 2009 | 11:52 PM
rrichar2591's Avatar
rrichar2591
How far have you driven since changing the battery? I find that it takes a few miles to reset the tps after putting air in the tires etc. If the back ones work the front ones should also. Good luck
Old Oct 8, 2009 | 12:31 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
could just be coincidence that TPS sensors are bad or need reprogramming...
Old Oct 11, 2009 | 05:12 PM
Joe Babe's Avatar
Joe Babe
try a strong magnet on you DIC code
Old Oct 11, 2009 | 06:36 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Drive it a few miles first and if that doesn't help reprogram the sensors.
Old Oct 11, 2009 | 07:33 PM
dobewillie's Avatar
dobewillie
good luck
Old Oct 11, 2009 | 07:35 PM
jrose7004's Avatar
jrose7004
I didn't have any issues when I replace my battery a couple of years ago.
To C-5 Battery replacement
