C5 Turn Signal and Corner Lights
I purchased a 2002 Convertible with lots of miles. The Turn Signal and Corner Lights have some serious 'wear' and I would like to replace them.
What brand do you recommend and how hard are they to replace? I would like to get replacements that are brighter(amber bulbs) than the stock ones. Thanks in advance for your help.
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Check out our clear corners. They are pretty easy to install.
http://forums.corvetteforum.com/c5-p...r-corners.html
We have several LED enhancements for the bulbs, but really won't be brighter than stock. They will be as bright as stock, but mainly just look better.
If you have questions contact me direct.
Banned Scam/Spammer
Yeah the bottom is a lot easier.
Our very own moderator Pewter99 wrote the best DIY I have found
http://forums.corvetteforum.com/1561976208-post3.html
my thread with pics of corners and ramps
http://forums.corvetteforum.com/c5-g...-projects.html
took me about an hour, after fumbling around without direction for 15-20 minutes on the first side.. i had to go from the top side, which is tougher..its cake after that..good luck
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I bought the Blitz ramps from walmart, they're $42.
Best part is . . .no more blown bulbs due to hot halogens melting the connectors and the top of the carriers
If you go for LED's you may want to look at the flasher bypass also. The LED's draw so much less current that the oem flasher thinks the bulb is blown. This cycles the flash time to a faster rate (called hyperflash). Wont actualy hurt anything but technicaly the rears are still gonna be incandescent bulbs and cycling that fast will burn those out faster.
The Flasher bypass just plugs in under the dash (three screws and ten minutes) no cutting/splicing. With it installed the lights work the same as the oem lights.
