Check engine light
Old Oct 7, 2009 | 10:34 PM
ontcanuck's Avatar
ontcanuck
Default Check engine light
Drove my 01 down the road to-day and after about 15 min. the check engine light comes on. Did a search on the forum but only found the ones with C6s had problems. A number of them had suggestions anything from disconnecting the negative side of the battery for 15 min.or buying a code reader about $ 60.00. Welcome any suggestions
Old Oct 7, 2009 | 10:40 PM
ALLEGRO's Avatar
ALLEGRO
Follow the instructions on how to read codes, and then write down what yours are. After you write them down, do it again and delete them if it is an "H" code (history) as it is no longer a problem.
Good Luck
Old Oct 8, 2009 | 07:47 AM
ontcanuck's Avatar
ontcanuck
Good Luck
I have not bought a code reader is there a simpler way?
Old Oct 8, 2009 | 08:47 AM
Vega$Vette's Avatar
Vega$Vette
Here you go
http://www.stengel.net/diccodes.htm
Old Oct 8, 2009 | 09:15 AM
85alusion's Avatar
85alusion
Originally Posted by Vega$Vette
Not my thread but thanks I needed this info.
Old Oct 8, 2009 | 09:27 AM
urfubar's Avatar
urfubar
Old Oct 8, 2009 | 10:07 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
You dont need a code reader, press and release the FUEL button 4x while holding the OPTIONS button. It will scroll automatically but you can scroll through it manually.
Old Oct 10, 2009 | 11:11 AM
ontcanuck's Avatar
ontcanuck
thanks guys problem solved
To Check engine light
