headlight issue
Old Oct 10, 2009 | 10:38 AM
jeepguy99's Avatar
jeepguy99
5th Gear
Default headlight issue
this is on a 03 coupe, when i turn the lights of both headlights go down but the right side sounds like he keeps going. i tired a search and couldnt find anything, any help would be great
Old Oct 10, 2009 | 10:58 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Sounds like a machine gun huh?
You need to replace the gear. I would do both while you're in there. I replaced one and had to go back about 6 months later to do the other.
http://forums.corvetteforum.com/c5-g...placement.html
I would go with these brass gears
http://www.rodneydickman.com/retail_new.html
Old Oct 10, 2009 | 11:27 AM
Oldvetter's Avatar
Oldvetter
Completely agree, a common problem.
Some think Bfranker gears are better because they are all metal (no rubber bushing).
http://www.bfranker.badz28.com/
I used Rodney Dickman's, he has a special bracket for later year C5s which holds the gear housing on (glue doesn't do a great job).
I bought 2 gears, but only put 1 in, other gear has gone several years now.
Old Oct 19, 2009 | 05:36 PM
PipeDr's Avatar
PipeDr
Thanks for the detailed information. It was I thought. Again, thanks for the very specific cure.
Old Nov 10, 2010 | 09:40 PM
SGNHERE's Avatar
SGNHERE
Has anyone tried the free fix on the bfranker site that is used for the Firebirds? Will this work for Corvette headlight?
To headlight issue
