No cats in AZ?
If you are going with LT's, why not go with a catted X-pipe and a tune, you'll have no worries.
With cats - you'll run cleaner and you won't have filthy exhaust tips from the untreated emissions.
I recommend Kooks with their catted X-pipe....that's what we sell the most of at Xtreme!
The AZ Revised State is ARS49-542.G1
http://www.azleg.gov/FormatDocument....49&DocType=ARS
Couldn't agree more. I intend to go with hi flow cats, was just wondering if someone could pass w/o any because it seems like a lot of people do just that.
Plus 96 and newer just get the computer checked for codes, no running on the rollers.
Just my $0.02 worth.
I agree. The Arizona County that I live in does not require emissions testing. But my car has the OEM Z06 X pipe with a B&B Bullet stinger and should pass emissions if ever tested.
Read the Code of Federal Regulations, Title 40, Part 86. If I recall correctly, that outlines the federal requirements for alterations/deletion of emissions control devices on vehicles operated on public highways. It can impose pretty heavy civil fines for owners and vendors.
Unfortunately, I predict every county in AZ will have it in some form eventually. To many people moved/moving here. Once construction starts again, the particulates add to the air quality. The crap in the air doesn't stop at county lines. Prior to the crash, Pinal County experienced one of the largest areas of growth. It would probably be the next logical county to require emissions testing. It was debated as recently as 2008, but nothing got passed.
FYI, unless it's changed some areas of Pinal County (Apache Junction, Maricopa, Queen Creek, Casa Grande) do require emissions testing if the owner/driver commutes into Maricopa County daily for work from their Pinal County primary residence.
You can find information here regarding metro Phoenix (area A) and metro Tucson (area B) and exemptions...
http://www.azdeq.gov/environ/air/vei/exempt.html
