Adjusting targa...
Old Oct 11, 2009 | 11:51 AM
Kale's Avatar
Kale
Default Adjusting targa...
I read a post about adjusting the targa top. It mentions loosening the bolts on the handle.
I thought one was the torx bolt, but I've destroyed two torx bits and it hasn't budged. Is there some other adjustment in the top itself?
Old Oct 11, 2009 | 12:26 PM
Turbopower87's Avatar
Turbopower87
Here are some links that might be helpful:
http://forums.corvetteforum.com/1570418541-post2.html
http://forums.corvetteforum.com/1569616267-post5.html
http://www.theredlion.us/window_blowout_clip.htm
http://www.theredlion.us/TipIn.htm
Old Oct 11, 2009 | 12:42 PM
Kale's Avatar
Kale
Yep, read all those before posting.
So how do you loosen the two latch handle bolts? "loosen" doesn't help, because I destroyed two torx bits trying to loosen them. They are in there like lug nuts.
Old Oct 11, 2009 | 06:34 PM
Kale's Avatar
Kale
I finally found a torx bit that could stand up to the torque. I've adjusted this thing 6 ways from sunday, the roof still doesn't sit low enough that the weatherstripping lines up with the car's weather stripping.
I was able to close the 1/4" gap by moving the pin back. But the top still needs to be pulled down 1/4" more, and I just don't see a way to do it.
To Adjusting targa...
