Check Engine Light On Dad's 98...Pulled The Codes...
Old Oct 11, 2009 | 01:27 PM
91LSMAN's Avatar
91LSMAN
Default Check Engine Light On Dad's 98...Pulled The Codes...
A couple months ago the check engine light on Dad's 98 came on, I pulled the codes, erased them and there has not been a problem since.
His check engine light came on again and I pulled the following codes:
P1154 H C
Found This on the Forum:
P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
Is this something he should have looked at?
The other codes were:
U1096 H
U1064 H
U1016 H
I know the "u" codes are not as important and that one or two of those are because he has an aftermarket audio system in his vette.
THANK YOU
Old Oct 12, 2009 | 09:58 PM
91LSMAN's Avatar
91LSMAN
Bump
Old Oct 12, 2009 | 10:46 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
U1096H
U1064H
U1016H
all have to do with a bad ground at G105
It is located under the block on the driver's side.
Bad things happen when this is not addressed. Don't panic but search for Bill Curlee (sp). He can show you exactly what to do and how!
Hope this helps. the other code you posted,,, I couldn't find my list tonite.....try google search Corvette DIC Codes Corvetteactioncenter!
Old Oct 13, 2009 | 01:46 AM
91LSMAN's Avatar
91LSMAN
Originally Posted by 8VETTE7
Sounds like one of the O2 sensors has failed. I would consider having it changed soon because they help keep the engine running with the correct air/fuel mixture which is good for both the engine, fuel economy and reducing the air pollution. Not that expensive unless you have a dealer do it.......
The U codes are usually loss of communication codes between the BCM and one or more sensors and if you clear them they should not come back for a while at least.
Originally Posted by Silverbullet00
U1096H
U1064H
U1016H
Thanks Guys.
To Check Engine Light On Dad's 98...Pulled The Codes...
