Headlight removal
Old Oct 13, 2009 | 12:19 PM
Dale M's Avatar
Dale M
Default Headlight removal
Hi guys does anyone know how and maybe have pictures on how to get the headlights out of a C5..I want the whole light out not just the bulbs.....Thanks Dale
Old Oct 13, 2009 | 12:26 PM
jrprich's Avatar
jrprich
When you say the whole thing, do you mean the entire assembly including the support frame ?
Old Oct 13, 2009 | 12:44 PM
Dale M's Avatar
Dale M
Default Just need the lights out
I only want the lights out,not just the bulbs so if its easier to take the whole flip up frame out then thats ok too.even getting the bulbs out are a pain.So Id like to get the whole thing out..I have a loose low beam socket so I need the light assembly out....Thanks...Dale
Old Oct 13, 2009 | 12:48 PM
j0n's Avatar
j0n
If you dont get the info by the time I get home from work @ 7pm I'll email you the light cannon install file, which has tons of pictures and a great install write-up including the sizes of every bolt/nut.
Old Oct 13, 2009 | 01:07 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Drive the car up on ramps.
Open the hood, remove the (2) T15 screws in the rear covers.
Turn on the lights and then disconnect the power cords.
Put some masking tape around the edge of the lights to prvenet scratches.
Remove the close-out panels under the front bumper (7mm).
(3) 10mm bolts behind on triangle shaped bracket and (3) 13MM bolts on frame.
Passenger side disconnect two plugs on the headlight control module before removing.
Old Oct 13, 2009 | 05:34 PM
Dale M's Avatar
Dale M
Default Lights
Thank you..Sounds like a real pain in the a__ just to get the lights out but I guess if thats the way then I have to do it...Think I should try and buy a shop manual for future questions..Thanks.....Dale
Old Oct 13, 2009 | 05:48 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Not really, it's about an hour job.
For manuals go to Gmpartshouse.com (aka Gene Culley).
Old Oct 13, 2009 | 06:10 PM
j0n's Avatar
j0n
Got home early, what's your email?
Old Oct 13, 2009 | 07:34 PM
Orphan's Avatar
Orphan
http://forums.corvetteforum.com/c5-t...with-pics.html
Post #2. Not exacty a step-by-step, but you can see the studs and mounting holes that attach the headlight assembly.
To Headlight removal
