Need help badly
Oct 13, 2009 | 06:23 PM
Need help badly
I posted earlier that I had no right rear turn signal or flasher. All others work. I've checked and rechecked the connections for the euro conversion I did 5 years ago and everything looks good. It is not getting any power to ths sockets. I checked the ground plug back tere and it looks good. A couple of people said change the flasher modual and I did today and still no help. Anyone got any ideas.
Thanks Laurence
Oct 13, 2009 | 07:07 PM
Did some more trouble shooting and if I jumper a wire from the drivers side to the passengers the flashers work but not the turn signals
Oct 13, 2009 | 08:50 PM
Did you check the ground wires?
Oct 13, 2009 | 09:45 PM
St. Jude Donor '08
Quote:
Originally Posted by
brit2001
Bad Turn Signal Stalk. Could try spraying in electrical cleaner.
How many miles on the car ?
Oct 13, 2009 | 11:27 PM
St. Jude Donor '08
ajg1915
bingo!!!!!! just get a new stalk and replace it. I went through this exact same issue you are describing. let me know if you need a write up on how to change it. it is a simple enough fix and shouldn't cost too much for the part.
Oct 14, 2009 | 05:40 PM
I haven't tryed to clean the switch yet. How much is a new stalk?
Oct 14, 2009 | 05:57 PM
Hope you get it fixed......By the way that is a sweet looking ride in your avatar
Oct 14, 2009 | 06:18 PM
Thanks ATMSRUS1 I need to update the pic. The back end is now gloss blackamong other things.
Oct 14, 2009 | 07:27 PM
St. Jude Donor '08
brit2001
$200 or so. Order from GMpartshouse.com (aka Gene Culley)
Oct 14, 2009 | 09:51 PM
Oct 14, 2009 | 09:54 PM
Oct 16, 2009 | 10:47 AM
Thanks guys. The mulifunction switch is the problem. Will be getting on order today.
Laurence
Oct 16, 2009 | 01:25 PM
Glad you got it diagnosed. Good luck installing the part.
Oct 16, 2009 | 07:33 PM
