[Z06] Serpentine Belt Problem + Overheating Issues
Old Oct 15, 2009 | 08:11 PM
FerrariFr34k's Avatar
FerrariFr34k
Default Serpentine Belt Problem + Overheating Issues
I was driving on the highway at about 70mph when all of a sudden the water temp skyrocketed and the "Reduced Engine Power" & "Coolant Over Temp" appeared upon my DIC. I let off the gas and coasted to a halt with the engine turned off. When I lifted to hood to diagnose the issue, BOTH serpentine belts were off and the coolant was BOILING. The bolt on the Harmonic Balancer was loose and the pulley was not stable although I just had these parts replaced 1 month ago. After pitching a small fit on the side of the road @ 2am, I gathered myself and continued searching for issues. I wasn't able to COMPLETELY locate the source, but there was OIL & COOLANT all over the place.
The engine DID NOT make any kind of sounds that might be considered "Game Over" if you know what I mean, and the shop foreman @ the stealership told me that they would fix the HB, pulley, and the busted seals.
HOWEVER, should I be worried about any major engine problems even though they are not currently apparent?
Old Oct 15, 2009 | 09:07 PM
speedyhawk101's Avatar
speedyhawk101
Hopefully the engine did not get too hot. My guess is that Aluminum components are more prone to warpage.
Old Oct 16, 2009 | 01:04 PM
bmg's Avatar
bmg
Sounds like your waterpump locked up?
Old Oct 16, 2009 | 03:02 PM
Z06_BluByU's Avatar
Z06_BluByU
or the crank pulley worked its way loose.. (no properly torqued)..
I suppose a compression and leak down check wouldnt hurt as a baseline indicator of wear.. go from there.. if they can fix it no cost.. great!
Old Oct 18, 2009 | 08:07 PM
Paul 75 L82's Avatar
Paul 75 L82
Without any noise you're probally be OK.
To Serpentine Belt Problem + Overheating Issues
