[Z06] Just ordered GHL
Old Oct 15, 2009 | 10:23 PM
QUIKSILVERZ's Avatar
QUIKSILVERZ
Default Just ordered GHL
Just ordered a GHL catback from CCA tonight . Chip said it should be shipping out in the am. Man i cant wait to get them on. Right now the car has ARH long tubes / ORX pipe with the stock Ti catback. Love the sound of the Ti but just not loud enough or deep enough for me. post up some before and after videos when i get them installed.
Old Oct 16, 2009 | 12:55 AM
wildbill ws6/ss's Avatar
wildbill ws6/ss
sweet
Old Oct 16, 2009 | 01:00 AM
TheDingo's Avatar
TheDingo
congrats! Look forward to the vid
Old Oct 17, 2009 | 11:47 AM
ttribe's Avatar
ttribe
my car with cam/headers and Ti
after swapping the Ti for the GHL. I like it a little better
Old Oct 17, 2009 | 11:53 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Your going to love them !
They really bring out the crack/crack/crack sound of my cam.
You can hear it in ttribe's video's above also.
Toque
Old Oct 18, 2009 | 10:05 AM
QUIKSILVERZ
ttribe it sounds a lot better imo! they should be here tues.
Old Nov 2, 2009 | 03:50 PM
QUIKSILVERZ
stock ti
ghl bullets
i could not be happier with the GHL kit! It is loud at WOT but i am not running cats. There is some drone (for example when i am in 6th gear/below 60mph). Any throttle imput produces some drone until i get above 60mph. But if you are on the highway above 60 in 6th the car is not much louder than the stock Ti was. The car sounds soooo much better now. It has a deep rumble to it and at WOT it sounds like a race car. I notice people rolling down their windows a little to hear it at red lights lol. The kit also really looks great imo. It is heavier than the stock Ti but i would think with the weight i saved by putting the headers/ORX on the car is at a very similar total weight as it was stock.
Two things i did not like about the kit though. First was the pipes that have the tips on them were not even which caused some tip alignment issues. I used torctite band clamps instead of the GHL clamps which ended up giving me enough room to adjust the drivers side tip to match the passenger side. These band clamps allowed me to pull the tip pipe out to the end of the muffler pipe with being to lose to stay inplace. The torctite clamps are top notch products. Second i was running a WCC billet exhaust plate and had to remove it do to clearence issues with the passenger side tip pipe. If the exhaust moved any (under WOT) it would strike the plate. I tried multiple times to adjust the tips and i could not get them to match. One tip would be at a down angle and the other would be on a upward angle. I ended up pulling the plate off and the tips now are perfect.
Old Nov 2, 2009 | 07:29 PM
ttribe's Avatar
ttribe
Originally Posted by QUIKSILVERZ
stock ti
ghl bullets
Still at work, so can't watch the video until I get home...
but i am glad you posted about the billet exhaust plate... I was going to order one, now I will need to check for clearance first! How thick are they anyways?
Old Nov 2, 2009 | 11:05 PM
The Stranger's Avatar
The Stranger
Did you try adjusting the pipes that go over the axle? It takes minute adjustments at all 4 points to get the tips equal. It takes some time but it's doable.
Old Nov 2, 2009 | 11:21 PM
wildbill ws6/ss
can you tell a power difference between the 2?
Old Nov 2, 2009 | 11:51 PM
The Stranger
No.
Old Nov 3, 2009 | 08:28 AM
QUIKSILVERZ
nope. sounds faster though lol.
tips are perfect now but i just cld not get the passenger side tips to clear the exhaust plate and be at the same angle as the drivers. it could be that the bend in the pipe coming off the passenger muffler could have been a little off.
To Just ordered GHL
